[mapguide-users] RE: GDAL FDO Issues
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Wed Jun 17 21:35:49 EDT 2009
Mine are each about 4Mb -pretty small....I'm pointing to a folder with
about 6 of them.
Mark Nichols wrote:
> Andrew, What size files are you using? Mine are < 600 MB. Does size
> matter. Most likely I have something out of place, just can't find what.
> Mark
> On 6/17/09 9:07 PM, "Andrew DeMerchant" <andrew.demerchant at gemtec.ca> wrote:
>> I've been trying to make the gdal work for 2.1 for a week or 2 now, with
>> the help of this group.....but still no go.
>> Andrew
>> Mark Nichols wrote:
>>> Still is not working. I'll step through the instructions again and make
>>> sure I'm doing it right.
>>> Anything else that could have changed. What about the world file. I have a
>>> folder with the sid and the sdw.
>>> I re-created the data connection and layer, still nothing showing.
>>> Mark Nichols
>>> markn at spicergroup.com
>>> On 6/17/09 7:41 PM, "Jason Birch" <Jason.Birch at nanaimo.ca> wrote:
>>>> Are you using the new MrSID plugin referenced in this post?
>>>> http://n2.nabble.com/ECWs-and-MG-2.1-tp2978248p2978703.html
>>>> If this works for you and you have time, it would be awesome if you could
>>>> add
>>>> it to the FDO wiki. I haven't had a chance yet:
>>>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>>>> Jason
>>>> -----Original Message-----
>>>> From: Nichols, Mark A.
>>>> Sent: Wednesday, June 17, 2009 4:16 PM
>>>> Subject: [mapguide-users] GDAL FDO Issues
>>>> I'm working with MGOS 2.1. I did have my sid's working in 2.0 but no longer
>>>> when I upgraded.
>>>> Yes, the coordinate system on the data does match that of the map. I turned
>>>> on the debugging but don't see anything new in the log.
>>>> I think that I may have my files in a wrong locaton. Here's my file
>>>> structure:
>>>> Server\bin
>>>> Server\FDO
>>>> Server\gdalplugins
>>>> Server\gdalplugins\gdal_ECW.dll
>>>> Server\gdalplugins\gdal_MrSID.dll
>>>> Does this look good so far?
>>>> Any suggestions?
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Mark Nichols
>>> Project Manager
>>> Spicer Group, Inc.
>>> 230 S. Washington Avenue
>>> Saginaw, MI 48607
>>> Phone: (989) 754-4717
>>> Fax: (989) 754-4440
>>> mailto: markn at spicergroup.com
>>> www.spicergroup.com
>>> Stronger. Safer. Smarter. Spicer
> Mark Nichols
> Project Manager
> Spicer Group, Inc.
> Saginaw, MI 48607
> Fax: (989) 754-4440
> www.spicergroup.com
