[mapguide-users] active selection on the dwf viewer MG 2010
Neele
Berit.Schaefer at gmx.de
Thu Jun 18 09:08:05 EDT 2009
Hi guys,
I’ve the following problem with the selection on the DWF Viewer.
I’am trying to set a active selection on the map using the web API (asp.net
VB). My code seems to run just finde with the AJAX Viewer but when I try to
select a Feature on the dwf viewer it doesn’t work.The Status-bar doesn’t
show an selected object as well. There is no error on the whole page.
Furthermore the XmlString is fine as well. I’ve tried nearly everything I
could found……
Seem like the selection command isn’t working right on the DWF Viewer.
Does anyone have experience with the issue?
Code:
***************************************************************************___________________________________________________________________________
Dim FeatureResID As New
MgResourceIdentifier("Library://Ordner/Daten/BP.FeatureSource")
Dim selection As New MgSelection(map)
Dim featureReader As MgFeatureReader
Dim queryoption As New MgFeatureQueryOptions
Dim layer As MgLayer
layer = map.GetLayers.GetItem("BAUPLATZ")
For i As Integer = 0 To o
Dim ID_string As String = "NUMMER= '" + r(i) + "' "
queryoption.SetFilter(ID_string)
featureReader = featureService.SelectFeatures(FeatureResID, "
BP:BAUPLATZ", queryoption)
'_________________________________________________________________
featureReader = layer.SelectFeatures(queryoption)
selection.AddFeatures(layer, featureReader, anzahl)
Dim pp As Integer = 1
anzahl += 1
If i = o Then selection.Save(resourceService, mapname) :
featureReader.Close()
Next
str = selection.ToXml
javascript:
var selXML='<%=str %>';
parent.kartenFrame.viewerFrame.mapFrame.SetSelectionXML(selXML);
View this message in context: http://n2.nabble.com/active-selection-on-the-dwf-viewer-MG-2010-tp3113153p3113153.html
