[mapguide-users] ODBC Data - Searching with "Search" tools in layout causes mgserver.exe to through exception and die...
Dave Wilson dave.wilson at autodesk.com
Tue Jun 23 16:00:22 EDT 2009
I can't reproduce this in house.
1) The exception getting thrown when you zoom seems to be an important detail we are missing here
2) When you say you are updating the database via PHP are you using the MapGuide API or your own PHP coding and ODBC connection?
3) Are you using Apache or IIS? If IIS have you modified the connection limit setting to prevent problems?
4) What browser (and version are you using)?
For the server to crash it suggests that something is out of sync such as old or new dlls are mixed somehow?
Was the install/upgrade a clean wipe of directories?
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Tuesday, June 23, 2009 9:09 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] ODBC Data - Searching with "Search" tools in layout causes mgserver.exe to through exception and die...
So there is no error in your mapguide server error log prior to this?
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Micallef
Sent: Tuesday, June 23, 2009 8:28 AM
To: mapguide-users at lists.osgeo.org
Sorry - I was out of the office. [http://n2.nabble.com/file/n3142786/Untitled-1.gif] Just a general exception error.
View this message in context: RE: ODBC Data - Searching with "Search" tools in layout causes mgserver.exe to through exception and die...<http://n2.nabble.com/ODBC-Data---Searching-with-%22Search%22-tools-in-layout-causes-mgserver.exe-to-through-exception-and-die...-tp3113001p3142786.html>
Sent from the MapGuide Users mailing list archive<http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090623/4c03ae37/attachment.html
