[mapguide-users] ODBC Data - Searching with "Search" tools in layout causes mgserver.exe to through exception and die...
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 18 10:09:06 EDT 2009
which version / platform ?
On Thu, Jun 18, 2009 at 10:34 PM, Micallef, Michael
(MTO)<Michael.Micallef at ontario.ca> wrote:
> Hi all,
> I am using an odbc connection to an access database. The data the connection
> is using is a View defined inside the access database. There is lat long
> data in the View and it maps in MapGuide fine (single point symbol) – I can
> update the lat/long values fine in the access data through interaction on
> the map and using an additional odbc connection in php to update the
> location of the point.
> When I search using the map studio “Search” created tool (even on just
> opening the map – i.e. no php odbc connection) – it returns the records in
> the list in the task frame from the search but shortly after clicking a
> return item to zoom to the point, mgserver .exe throws an exception and
> holds up the sever for a couple minutes – it will eventually zoom to the
> point – but the server never functions properly afterwards and need to be
> restarted…
> Has anyone seen this or know of a work –around?
> Mike
> Michael Micallef - PMP
> michael.micallef at ontario.ca
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
