[mapguide-users] ODBC DataSource creation
Zac Spitzer zac.spitzer at gmail.com
Thu Jun 18 21:03:01 EDT 2009
any reason you not using king oracle, ie a native FDO provider rather than ODBC?
On Fri, Jun 19, 2009 at 11:01 AM, Joel Carranza<jec at gatekeeper.com> wrote:
> I'm creating a a new ODBC DataSource which is pointed at an Oracle database.
> This database has a lot of table/views in it, and when I go to define my
> geometry properties and hit "Show tables", the takes a really long to to
> populate. However, after a couple of minutes, everything comes up.
> Wonderful! (This hadn't worked at all in older releases)
> However, after setting up everything the way I want it, I go to hit the save
> button and it takes a long time to save the datasource.
> Really long - like 15 minutes. (it did eventually complete though)
> Looking at the query log, we see that for each table that i defined an x/y
> column, the ODBC FDO is doing
> SELECT B.lat FROM tablename B
> and then
> SELECT B.lon FROM tablename B
> Ouch!Each of our tables are actually quite big, so this kind of query takes
> forever. I am guessing that the FDO is doing this to calculate the spatial
> extent of the data, but why would it do it this way? Why not using MIN/MAX?
> Is there something wrong with my setup that may be causing the code to go
> down this path?
> I am setting up against Views  inside an Oracle 10.2 database with the
> latest MapGuide Open Source 2.1 beta. I think that I have seen this behavior
> in earlier releases.
> Any thoughts?
> Many thanks
> Joel Carranza
> Gatekeeper Systems
> View this message in context: http://n2.nabble.com/ODBC-DataSource-creation-tp3116879p3116879.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
