[mapguide-users] google mapintegration with mapguide
GordonL
gordon.luckett at arrowgeomatics.com
Fri Jun 19 12:41:03 EDT 2009
Were you ever able to solve this one?
I can put the google maps over my map using the Spherical Mercator
projection, but my Overview map in FUSION does not appear. I think the
custom coordinate system is causing the overview map to hang?
I have set my overview map to the same map (spherical Mercator) and tried
some other maps (LL and UTM) but the overview map will not appear if I use
the custom coordinate system in my main map.
oh, here is the spherical Mercator:
PROJCS["Popular Visualisation CRS / Mercator", GEOGCS["Popular Visualisation
CRS", DATUM["Popular Visualisation Datum", SPHEROID["Popular Visualisation
Sphere", 6378137, 0, AUTHORITY["EPSG",7059]], TOWGS84[0, 0, 0, 0, 0, 0, 0],
AUTHORITY["EPSG",6055]], PRIMEM["Greenwich", 0, AUTHORITY["EPSG", "8901"]],
UNIT["degree", 0.0174532925199433, AUTHORITY["EPSG", "9102"]], AXIS["E",
EAST], AXIS["N", NORTH], AUTHORITY["EPSG",4055]], PROJECTION["Mercator"],
PARAMETER["False_Easting", 0], PARAMETER["False_Northing", 0],
PARAMETER["Central_Meridian", 0], PARAMETER["Latitude_of_origin", 0],
UNIT["metre", 1, AUTHORITY["EPSG", "9001"]], AXIS["East", EAST],
AXIS["North", NORTH], AUTHORITY["EPSG",3785]]
regards
gordon
girish kumar bv wrote:
> Hi all,i am able to bring google map as a base layer into mapguide
> using fusion, map is showing up in the legend list but it is not appearing
> on google maps or overview map, however google map is zooming to the
> required area of interest. Can anyone tell me the solution for this. Any
> help is appreciatedregards,girish
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/re%3A-google-mapintegration-with-mapguide-tp3049773p3120765.html
