[mapguide-users] MGE 2010: fusion pre-authentication (autologin) no longer works
Andy Morsell amorsell at spatialgis.com
Mon Jun 22 17:37:30 EDT 2009
Can anyone confirm that this is a problem with MGOS 2.1 beta?  It probably
is since it uses the same version of Fusion as MGE 2010...... This ticket
entry to the MGOS Trac looks like the same or similar issue:
http://trac.osgeo.org/mapguide/ticket/1021.  It's confusing since it shows
the version as 2.0.2 and I have a 2.0.2 application that works fine with the
SESSION parameter.  I did not see any Fusion Trac tickets related to this
problem.
If this problem exists in 2.1 it will prevent me from upgrading my
production server as I use the same method to bypass authentication after
programmatically establishing a session.
Andy Morsell, P.E.
Spatial Integrators, Inc.
47° 46' N 116° 49' W
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
Sent: Monday, June 22, 2009 1:39 PM
To: mapguide-users at lists.osgeo.org
Subject: SPAM-LOW: Re: [mapguide-users] MGE 2010: fusion pre-authentication
Hi, I am having the same problem:
http://squamish2010.ca/mapguide2010/fusion/templates/mapguide/googleaqua/ind
ex.html?APPLICATIONDEFINITION=Library://Contaminants/Layouts/Contaminants_Fl
exible_Layout.ApplicationDefinition&SESSION=10d6c434-4199-102c-8000-00505600
0000_en_7F0000010AF20AF10AF0
this link (when the session is active) works great in Safari and Internet
Explorer
but FIREFOX still wants an authentication??
Did anyone figure this one out?
thanks
gordon
David Hequet wrote:
> Hi,
> i'm experiencing the same issue: MGE 2010 With Firefox 3.0.6 or 3.0.10
> don't use the session parameters.
> Did you find a solution?
> David Hequet
> Jani Forssell wrote:
>> Hi,
>> We're using the standard Fusion authetication code that opens a
>> connection to the MG site and creates a session and then passes it to
>> the fusion viewer via the "Session" query parameter. It used to work
>> with MGE 2009, but no longer works with MGE 2010. At least with Firefox
>> 3.0.8 I get a login dialog from MapGuide. With IE8 and Chrome I don't.
>> Here's the code:
>> try
>>    MapGuideApi.MgInitializeWebTier(@"C:\Program
>> Files\Autodesk\MapGuideEnterprise2010\WebServerExtensions\www\webconfig.
>> ini");
>>    MgUserInformation userInfo = new MgUserInformation(defaultUser,
>> defaultPassword);
>>    MgSite site = new MgSite();
>>    site.Open(userInfo);
>>    sessionId = site.CreateSession();
>> Response.Redirect("../fusion/templates/mapguide/slate/index.html?Applica
>> tionDefinition=" + webLayout + "&Session=" + sessionId);
>> catch (Exception e)
>>    Response.Write(e.Message);
>> An example URL generated is:
>> http://server/mapguide2010/fusion/templates/mapguide/slate/index.html?Ap
>> plicationDefinition=Library://Samples/Sheboygan/Layouts/Flexiblegan.Appl
>> icationDefinition&Session=f7b8db74-04e7-102c-8000-000c299e04c9_en_3EEC8C
>> A00AF20AF10AF0
>> Any ideas on how to get this working with MGE 2010?
>> Regards,
>> Jani Forssell
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context:
http://n2.nabble.com/MGE-2010%3A-fusion-pre-authentication-%28autologin%29-n
o-longer-works-tp2592934p3138583.html
