[mapguide-users] MGE 2010: fusion pre-authentication
(autologin) no longer works
GordonL
gordon.luckett at arrowgeomatics.com
Thu Jun 25 13:43:02 EDT 2009
Andy, have you tried it? I am struggling with MapGuide/FUSION and firefox
authentication. It's werid the the GET will not work with the SESSION for
FIREFOX.
gordon
Andy Morsell wrote:
> Can anyone confirm that this is a problem with MGOS 2.1 beta? It probably
> is since it uses the same version of Fusion as MGE 2010...... This ticket
> entry to the MGOS Trac looks like the same or similar issue:
> http://trac.osgeo.org/mapguide/ticket/1021. It's confusing since it shows
> the version as 2.0.2 and I have a 2.0.2 application that works fine with
> the
> SESSION parameter. I did not see any Fusion Trac tickets related to this
> problem.
> If this problem exists in 2.1 it will prevent me from upgrading my
> production server as I use the same method to bypass authentication after
> programmatically establishing a session.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of GordonL
> Sent: Monday, June 22, 2009 1:39 PM
> To: mapguide-users at lists.osgeo.org
> Subject: SPAM-LOW: Re: [mapguide-users] MGE 2010: fusion
> pre-authentication
> Hi, I am having the same problem:
> http://squamish2010.ca/mapguide2010/fusion/templates/mapguide/googleaqua/ind
> ex.html?APPLICATIONDEFINITION=Library://Contaminants/Layouts/Contaminants_Fl
> exible_Layout.ApplicationDefinition&SESSION=10d6c434-4199-102c-8000-00505600
> 0000_en_7F0000010AF20AF10AF0
> this link (when the session is active) works great in Safari and Internet
> Explorer
> but FIREFOX still wants an authentication??
> Did anyone figure this one out?
> thanks
> gordon
> David Hequet wrote:
>> Hi,
>> i'm experiencing the same issue: MGE 2010 With Firefox 3.0.6 or 3.0.10
>> don't use the session parameters.
>> Did you find a solution?
>> David Hequet
>> Jani Forssell wrote:
>>> Hi,
>>> We're using the standard Fusion authetication code that opens a
>>> connection to the MG site and creates a session and then passes it to
>>> the fusion viewer via the "Session" query parameter. It used to work
>>> with MGE 2009, but no longer works with MGE 2010. At least with Firefox
>>> 3.0.8 I get a login dialog from MapGuide. With IE8 and Chrome I don't.
>>> Here's the code:
>>> try
>>> MapGuideApi.MgInitializeWebTier(@"C:\Program
>>> Files\Autodesk\MapGuideEnterprise2010\WebServerExtensions\www\webconfig.
>>> ini");
>>> MgUserInformation userInfo = new MgUserInformation(defaultUser,
>>> defaultPassword);
>>> MgSite site = new MgSite();
>>> site.Open(userInfo);
>>> sessionId = site.CreateSession();
>>> Response.Redirect("../fusion/templates/mapguide/slate/index.html?Applica
>>> tionDefinition=" + webLayout + "&Session=" + sessionId);
>>> catch (Exception e)
>>> Response.Write(e.Message);
>>> An example URL generated is:
>>> http://server/mapguide2010/fusion/templates/mapguide/slate/index.html?Ap
>>> plicationDefinition=Library://Samples/Sheboygan/Layouts/Flexiblegan.Appl
>>> icationDefinition&Session=f7b8db74-04e7-102c-8000-000c299e04c9_en_3EEC8C
>>> A00AF20AF10AF0
>>> Any ideas on how to get this working with MGE 2010?
>>> Regards,
>>> Jani Forssell
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://n2.nabble.com/MGE-2010%3A-fusion-pre-authentication-%28autologin%29-n
> o-longer-works-tp2592934p3138583.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/MGE-2010%3A-fusion-pre-authentication-%28autologin%29-no-longer-works-tp2592934p3156559.html
