[mapguide-users] MSSqlServer Spatial problem
zolinko
zolinko at freemail.hu
Wed Jun 24 09:26:31 EDT 2009
Hi All,
I have a problem inserting geometry into MSSqlServer2008 with the spatial
provider through Mapguide Enterprise 2010.
The whole process is completely working with the NON spatial fdo provider
(where the geometry fields in the db are typed as 'image')
But when I change the provider and define the geometry fields 'Geometry', it
doesn't work.
It doesn't throw any exception, (not seen anything in db log, mapguide log
or client log), and it is not hangs.
simply the mapguide process takes 100% cpu time for even an hour (or more,
then I restrarted it)
I use the MgAgfReaderWriter, to write the geometry to the GeometryProperty
and than
use the featureService.UpdateFeature method.
If anyone has some experience (or code example) on how to use mssql spatial
from mapguide,
please, let me know.
Any idea will be appreciated.
TIA
zolinko
View this message in context: http://n2.nabble.com/MSSqlServer-Spatial-problem-tp3148712p3148712.html
