[mapguide-users] Missing tiles
Peter Filip
reklamama at centrum.sk
Wed Jun 24 15:49:26 EDT 2009
Joel Carranza wrote:
> Check your error log on the server. If a tile fails to render because of
> whatever reason, it still creates a tile
> See RFC 64 - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc64
> "Currently an exception thrown during the stylization code for a tile is
> caught and ignored. This can lead to partially incomplete tiles which are
> hard to detect as no error information is passed via the API. Even worse
> the tile is kept in the tilecache!"
> --joel
> Peter Filip wrote:
>> I have created a tiled layer using Maestro MgCooker. Everything was
>> processed flawlessly.
>> But after loading the tiled layer in the ajaxviewer there are some
>> missing tiles.I have opened the page from different computers with the
>> same result. I also re-generated the whole layer but with no success.This
>> "hole" in the layer dont occurs in all scales, just in some, but at the
>> same place.
>> Here is a preview
There's no log entry. Is there any workaround ?? I'm using MGOS 2.0.2.
View this message in context: http://n2.nabble.com/Missing-tiles-tp3149760p3151011.html
