[mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
Jackie Ng
jumpinjackie at gmail.com
Thu Jun 25 07:52:32 EDT 2009
Are you sure you weren't using the mapguide enterprise mapagent?
- Jackie
Gyufi wrote:
> Hi.
> I installed MapGuide Open Source 2.0.2 to a server, where already
> installed Autocad Map 3D 2009, Topobase Web 2009 (MapGuide Enterprise and
> Studio in it), MapGuide 6.5 and Raster Design 2009.
> I was surprised, when I used the GetBaseLibrary function in mapagent of
> the Open Source 2.0, it wrote out this:
> "Mentor Coordinate System Library"
> But!
> When I installing MapGuide Open Source 2.0.2 to an another computer, where
> installed just Topobase (Client and Administrator) 2009, and I using the
> GetBaseLibrary function in mapagent of the Open Source 2.0, it write out
> this:
> "PROJ4 Coordinate System Library"
> MapGuide Open Source 2.0.2 using PROJ4, I know, but then how can use
> Mentor automatically when I install to a Server, where another MapGuide
> versions on it?
> I went through out the whole registry.
> I searched for MapGuide, cs-map, mentor, proj4, proj_lib, gdal_data
> entries, but when I found something, it was the same in both windows
> registry.
> Can anybody help me in this problem?
> Gyufi
View this message in context: http://n2.nabble.com/MapGuide-Open-Sourc-2.0.2-how-can-use-Mentor--tp3154353p3154575.html
