[mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
Gyufi endre.budai at geoview.hu
Thu Jun 25 08:18:05 EDT 2009
Hi Jackie,
Thank you for answer.
I using this link:
http://localhost/mapguide/mapagent/index.html
this is the mapagent of MapGuide Open Source.
I can use the mapagent of MapGuide Enterprise with this link:
http://localhost/mapguide2009/mapagent/index.html
It's weird, because I can't use PHP functions in MGOS mapagent, just html.
PHP functions writes out this:
"Invalid access to memory location."
In IIS the path of the fcgi extent is right:
"C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapagent\isapi_MapAgent.dll"
Do you have any idea?
Thank you in anticipation.
Gyufi
Jackie Ng wrote:
> Are you sure you weren't using the mapguide enterprise mapagent?
> - Jackie
> Gyufi wrote:
>> Hi.
>> I installed MapGuide Open Source 2.0.2 to a server, where already
>> installed Autocad Map 3D 2009, Topobase Web 2009 (MapGuide Enterprise and
>> Studio in it), MapGuide 6.5 and Raster Design 2009.
>> I was surprised, when I used the GetBaseLibrary function in mapagent of
>> the Open Source 2.0, it wrote out this:
>> "Mentor Coordinate System Library"
>> But!
>> When I installing MapGuide Open Source 2.0.2 to an another computer,
>> where installed just Topobase (Client and Administrator) 2009, and I
>> using the GetBaseLibrary function in mapagent of the Open Source 2.0, it
>> write out this:
>> "PROJ4 Coordinate System Library"
>> MapGuide Open Source 2.0.2 using PROJ4, I know, but then how can use
>> Mentor automatically when I install to a Server, where another MapGuide
>> versions on it?
>> I went through out the whole registry.
>> I searched for MapGuide, cs-map, mentor, proj4, proj_lib, gdal_data
>> entries, but when I found something, it was the same in both windows
>> registry.
>> Can anybody help me in this problem?
>> Gyufi
View this message in context: http://n2.nabble.com/MapGuide-Open-Sourc-2.0.2-how-can-use-Mentor--tp3154353p3154672.html
