[mapguide-users] Missing tiles
Dave Wilson dave.wilson at autodesk.com
Thu Jun 25 11:15:42 EDT 2009
If one area of the map consistently fails at different scale ranges could there be some bad data involved? If you manually preview the Map or the Layout can you generate the tile?
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel Carranza
Sent: Thursday, June 25, 2009 9:04 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Missing tiles
If you can figure out what the tile is, you can either manually delete it
from the file system or via the mapagent. Then retry rendering the tile.
Other than that, sorry, I got no idea...
Peter Filip wrote:
> Joel Carranza wrote:
>> Check your error log on the server. If a tile fails to render because of
>> whatever reason, it still creates a tile
>> See RFC 64 - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc64
>> "Currently an exception thrown during the stylization code for a tile is
>> caught and ignored. This can lead to partially incomplete tiles which are
>> hard to detect as no error information is passed via the API. Even worse
>> the tile is kept in the tilecache!"
>> --joel
>> Peter Filip wrote:
>>> I have created a tiled layer using Maestro MgCooker. Everything was
>>> processed flawlessly.
>>> But after loading the tiled layer in the ajaxviewer there are some
>>> missing tiles.I have opened the page from different computers with the
>>> same result. I also re-generated the whole layer but with no
>>> success.This "hole" in the layer dont occurs in all scales, just in
>>> some, but at the same place.
>>> Here is a preview
> There's no log entry. Is there any workaround ?? I'm using MGOS 2.0.2.
View this message in context: http://n2.nabble.com/Missing-tiles-tp3149760p3155581.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
