[mapguide-users] Missing tiles
Kori Maleski
kori.maleski at gmail.com
Thu Jun 25 11:53:28 EDT 2009
Empty tiles - will be the same file size and be much smaller than other
tiles since they are of a single color.
You can manually delete these from the cache and let MapGuide automatically
rebuild them on demand.
Cheers,
On Thu, Jun 25, 2009 at 8:15 AM, Dave Wilson <dave.wilson at autodesk.com>wrote:
> If one area of the map consistently fails at different scale ranges could
> there be some bad data involved? If you manually preview the Map or the
> Layout can you generate the tile?
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] On Behalf Of Joel Carranza
> Sent: Thursday, June 25, 2009 9:04 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Missing tiles
> If you can figure out what the tile is, you can either manually delete it
> from the file system or via the mapagent. Then retry rendering the tile.
> Other than that, sorry, I got no idea...
> Peter Filip wrote:
> > Joel Carranza wrote:
> >> Check your error log on the server. If a tile fails to render because of
> >> whatever reason, it still creates a tile
> >> See RFC 64 - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc64
> >> "Currently an exception thrown during the stylization code for a tile is
> >> caught and ignored. This can lead to partially incomplete tiles which
> are
> >> hard to detect as no error information is passed via the API. Even worse
> >> the tile is kept in the tilecache!"
> >> --joel
> >> Peter Filip wrote:
> >>> I have created a tiled layer using Maestro MgCooker. Everything was
> >>> processed flawlessly.
> >>> But after loading the tiled layer in the ajaxviewer there are some
> >>> missing tiles.I have opened the page from different computers with the
> >>> same result. I also re-generated the whole layer but with no
> >>> success.This "hole" in the layer dont occurs in all scales, just in
> >>> some, but at the same place.
> >>> Here is a preview
> > There's no log entry. Is there any workaround ?? I'm using MGOS 2.0.2.
> http://n2.nabble.com/Missing-tiles-tp3149760p3155581.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090625/1493011a/attachment.html
