[mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
Gyufi endre.budai at geoview.hu
Thu Jun 25 11:48:15 EDT 2009
Thanks you Jason and Dave for answers!
> Jason wrote:
> Are the MGOS and MGE servers and web tiers configured to run on different
> port numbers?
MGOS and MGE using different ports.
MGE using 2800, 2801 and 2802.
MGOS using 2810, 2811 and 2812.
> Dave wrote:
> I noticed you don't have an 8008 port in your URLs. Does this mean you are
> using IIS?
You are right. I using IIS.
> Dave wrote:
> Site Admin is always PHP and Flexible Web Layouts use PHP so only one path
> to your php.ini will work under IIS.
Probably this is the problem. So I can't using more MapGuide on same server.
I'm sad. :(
Actually I interested in, how can I use Mentor with MGOS 2.0.2.
I updated the projections.xml and updated the Coordinate System of the map
in webstudio to use MapGuide the right Coordinate System, which it can
interpret, but MapGuide render a blank map, so it not drawn any feature to
the map.
I searching the solution for days, but I don't find it.
Maybe I can use only the MGOS 2.1 beta?
Regards,
Gyufi
View this message in context: http://n2.nabble.com/MapGuide-Open-Sourc-2.0.2-how-can-use-Mentor--tp3154353p3155849.html
