[mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
Dave Wilson dave.wilson at autodesk.com
Thu Jun 25 11:13:56 EDT 2009
I noticed you don't have an 8008 port in your URLs. Does this mean you are using IIS? If so only one instance of PHP will likely be valid which means you can only install one version of MapGuide and have it working properly? Site Admin is always PHP and Flexible Web Layouts use PHP so only one path to your php.ini will work under IIS.
In other words side by side installs of MapGuide under IIS won't work.
Just throwing that out there.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gyufi
Sent: Thursday, June 25, 2009 6:18 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
Hi Jackie,
Thank you for answer.
I using this link:
http://localhost/mapguide/mapagent/index.html
this is the mapagent of MapGuide Open Source.
I can use the mapagent of MapGuide Enterprise with this link:
http://localhost/mapguide2009/mapagent/index.html
It's weird, because I can't use PHP functions in MGOS mapagent, just html.
PHP functions writes out this:
"Invalid access to memory location."
In IIS the path of the fcgi extent is right:
"C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapagent\isapi_MapAgent.dll"
Do you have any idea?
Thank you in anticipation.
Gyufi
Jackie Ng wrote:
> Are you sure you weren't using the mapguide enterprise mapagent?
> - Jackie
> Gyufi wrote:
>> Hi.
>> I installed MapGuide Open Source 2.0.2 to a server, where already
>> installed Autocad Map 3D 2009, Topobase Web 2009 (MapGuide Enterprise and
>> Studio in it), MapGuide 6.5 and Raster Design 2009.
>> I was surprised, when I used the GetBaseLibrary function in mapagent of
>> the Open Source 2.0, it wrote out this:
>> "Mentor Coordinate System Library"
>> But!
>> When I installing MapGuide Open Source 2.0.2 to an another computer,
>> where installed just Topobase (Client and Administrator) 2009, and I
>> using the GetBaseLibrary function in mapagent of the Open Source 2.0, it
>> write out this:
>> "PROJ4 Coordinate System Library"
>> MapGuide Open Source 2.0.2 using PROJ4, I know, but then how can use
>> Mentor automatically when I install to a Server, where another MapGuide
>> versions on it?
>> I went through out the whole registry.
>> I searched for MapGuide, cs-map, mentor, proj4, proj_lib, gdal_data
>> entries, but when I found something, it was the same in both windows
>> registry.
>> Can anybody help me in this problem?
>> Gyufi
View this message in context: http://n2.nabble.com/MapGuide-Open-Sourc-2.0.2-how-can-use-Mentor--tp3154353p3154672.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
