[mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
Jason Birch
Jason.Birch at nanaimo.ca
Thu Jun 25 12:15:55 EDT 2009
Yes, the PHP.INI search path makes this annoying.
http://php.net/manual/en/configuration.file.php
I wonder if it would work to create a new app pool that runs under a specific user and setting the PHPRC environment variable for that user? Or to run both PHPs as CGI apps, remove the registry key, and rely on them picking up the PHP.ini from the install dir. This won't perform all that well, but I can't imagine running this combination of software on anything but a development PC anyway...
Jason
-----Original Message-----
Sent: Thursday, June 25, 2009 8:14 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] MapGuide Open Sourc 2.0.2 how can use Mentor?
I noticed you don't have an 8008 port in your URLs. Does this mean you are using IIS? If so only one instance of PHP will likely be valid which means you can only install one version of MapGuide and have it working properly? Site Admin is always PHP and Flexible Web Layouts use PHP so only one path to your php.ini will work under IIS.
In other words side by side installs of MapGuide under IIS won't work.
Just throwing that out there.
