[mapguide-users] MSSqlServer Spatial problem
zolinko
zolinko at freemail.hu
Tue Jun 30 04:49:09 EDT 2009
Hi Dave,
Yes, I also can insert with third patry software, or if I use directly the
FDO API.
But with Mapguide Web server API it is not possible.
I don't think it is a permission problem, since if I use FDO API,
I can insert and update with the same user (it is the owner of the schema).
It seems it is simply doesn't working in Mapguide...
Thx
zolinko
Dave Wilson wrote:
> I was using a third party application to try and insert into SQL Server
> Spatial and I was getting no errors whatsoever. It came down to a security
> issue. Does the userid used in your FeatureSource have insert/update
> permissions in the database? It seems you have select permissions.
> Dave
View this message in context: http://n2.nabble.com/MSSqlServer-Spatial-problem-tp3148712p3180199.html
