[mapguide-users] UpdateFeatures
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 2 05:45:34 EST 2009
what is the value of result.GetItem(0).GetValue() ?
On Mon, Mar 2, 2009 at 4:46 PM, Ivan Milicevic
<Ivan.Milicevic at supranet.hr> wrote:
> Hello Zac, hello group
> I'm havig the same problems as George has. Tried
> result.GetItem(0).GetValue() and resoult is 9. Can you help me? I'm
> really suffering to create this "easy to do" feature.
> The following code does it well, no execption, no errors but no deleted
> feature as well.
> PLease, be note that Filter string is fine.
> Thanx a lot.
> string TIMgisUser =
> System.Configuration.ConfigurationManager.AppSettings["TIMgisUser"];
> MapGuideApi.MgInitializeWebTier(@"C:\program
> files\MapguideOpenSource2.0\WebServerExtensions\www\webconfig.ini");
> MgUserInformation userInfo = new
> MgUserInformation("Administrator", "" +
> System.Configuration.ConfigurationManager.AppSettings["mgP"] + "");
> MgSite site = new MgSite();
> site.Open(userInfo);
> String mgSessionId = site.CreateSession();
> MgUserInformation userInfoNew = new
> MgUserInformation(mgSessionId);
> MgSiteConnection siteConnection = new MgSiteConnection();
> siteConnection.Open(userInfoNew);
> MgResourceService resourceService =
> siteConnection.CreateService(MgServiceType.ResourceService) as
> MgResourceService;
> MgFeatureService featureService =
> siteConnection.CreateService(MgServiceType.FeatureService) as
> MgFeatureService;
> MgResourceIdentifier resId = new
> MgResourceIdentifier("Library://PROJEKTI/ZLZ/PODACI/DIONICE.FeatureSourc
> e");
> MgFeatureCommandCollection commands = new
> MgFeatureCommandCollection();
> MgDeleteFeatures deleteCmd = new MgDeleteFeatures("DIONICE",
> "(FeatId='1')");
> commands.Add(deleteCmd);
> featureService.UpdateFeatures(resId, commands, false);
> string re = featureService.UpdateFeatures(resId, commands,
> false).GetItem(0).GetPropertyType().ToString();
> Response.Write(featureService.TestConnection(resId));
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Friday, August 01, 2008 3:06 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] MG 1.2 vs 2.0.1
> yep...it does fail silently, which is really annoying.. it should just
> raise an exception
> On Fri, Aug 1, 2008 at 4:16 AM, George McLean <gmclean at gorge.net> wrote:
>> No I am not. Does this ignore the error message and process the update
>> somehow?
>> Zac Spitzer wrote:
>>> Are you checking the result as bellow
>>> result=featureService.UpdateFeatures(resourceID, fCommand, false);
>>> if (result.GetItem(0).GetPropertyType() eq 9)
>>> result.GetItem(0).GetValue() // Silent FDO error messages!!!!
>>> z
>>> On Fri, Aug 1, 2008 at 2:14 AM, Zac Spitzer <zac.spitzer at gmail.com>
> wrote:
>>>> can you post some code to demonstrate the problem?
>>>> On Fri, Aug 1, 2008 at 2:05 AM, George McLean <gmclean at gorge.net>
> wrote:
>>>>> Hello,
>>>>> I am a bit stuck in upgrading to 2.0.1 mainly due to the issues
> with
>>>>> adding
>>>>> data to feature sources discussed in this thread:
> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-wa
> s-busy-to16392736.html#a18556960
>>>>> My immediate issue is that I have a client that would really like
> to us
>>>>> FF
>>>>> 3.0 with my application. I see that either I need to find a way to
> apply
>>>>> the
>>>>> fixes made in 2.0 for FF to 1.2 or find a way around the issues
> with
>>>>> updating feature data.
>>>>> I could look at the code for MG 1.2 and apply the changes made to
> 2.0
>>>>> with
>>>>> some guidance on where to start but I think I would rather find a
> fix
>>>>> for MG
>>>>> 2.0.
>>>>> Any suggestions would be appreciated.
>>>>> Thanks
>>>>> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
