[mapguide-users] Mapguide Crashing IIS (w3wp.exe) service or vice Versa
Flipper scotth at mpowerinnovations.com
Mon Mar 2 15:21:09 EST 2009
Keep getting this error(See Below) on one specific machine on a regular
basis...couldnt tell you whats different on this install from others...its
Windows 2003 Server SP2...Anyone have any ideas?
Application Errors:
Event Type:     Error
Event Source:   Application Error
Event Category: (100)
Event ID:       1000
Date:           3/2/2009
Time:           10:58:23 AM
User:           N/A
Computer:       SERVERNAME1
Description:
Faulting application w3wp.exe, version 6.0.3790.3959, faulting module
isapi_MapAgent.dll, version 2.0.2.3402, fault address 0x00001cf4.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 46 61 69 6c   ion Fail
0010: 75 72 65 20 20 77 33 77   ure  w3w
0018: 70 2e 65 78 65 20 36 2e   p.exe 6.
0020: 30 2e 33 37 39 30 2e 33   0.3790.3
0028: 39 35 39 20 69 6e 20 69   959 in i
0030: 73 61 70 69 5f 4d 61 70   sapi_Map
0038: 41 67 65 6e 74 2e 64 6c   Agent.dl
0040: 6c 20 32 2e 30 2e 32 2e   l 2.0.2.
0048: 33 34 30 32 20 61 74 20   3402 at
0050: 6f 66 66 73 65 74 20 30   offset 0
0058: 30 30 30 31 63 66 34      0001cf4
Event Type:     Error
Event ID:       1000
Date:           3/2/2009
Time:           10:58:20 AM
User:           N/A
Description:
Data:
Event Type:     Error
Event ID:       1000
Date:           3/2/2009
Time:           10:58:17 AM
User:           N/A
Description:
Data:
Event Type:     Error
Event ID:       1000
Date:           3/2/2009
Time:           10:58:14 AM
User:           N/A
Description:
Data:
Event Type:     Error
Event ID:       1000
Date:           3/2/2009
Time:           10:58:08 AM
User:           N/A
Description:
Data:
System Errors:
Event Type:     Warning
Event Source:   W3SVC
Event Category: None
Event ID:       1011
Date:           3/2/2009
Time:           10:58:10 AM
User:           N/A
Description:
A process serving application pool 'MapGuide' suffered a fatal communication
error with the World Wide Web Publishing Service. The process id was '4140'.
The data field contains the error number.
Data:
0000: 6d 00 07 80               m..?
Event Type:     Warning
Event Source:   W3SVC
Event ID:       1009
Date:           3/2/2009
Time:           10:58:14 AM
User:           N/A
Description:
A process serving application pool 'MapGuide' terminated unexpectedly. The
process id was '2264'. The process exit code was '0xc0000005'.
Event Type:     Warning
Event Source:   W3SVC
Event ID:       1011
Date:           3/2/2009
Time:           10:58:17 AM
User:           N/A
Description:
error with the World Wide Web Publishing Service. The process id was '6328'.
Data:
Event Type:     Warning
Event Source:   W3SVC
Event ID:       1011
Date:           3/2/2009
Time:           10:58:20 AM
User:           N/A
Description:
error with the World Wide Web Publishing Service. The process id was '2988'.
Data:
Event Type:     Warning
Event Source:   W3SVC
Event ID:       1011
Date:           3/2/2009
Time:           10:58:24 AM
User:           N/A
Description:
error with the World Wide Web Publishing Service. The process id was '6244'.
Data:
Event Type:     Error
Event Source:   W3SVC
Event ID:       1002
Date:           3/2/2009
Time:           10:58:24 AM
User:           N/A
Description:
Application pool 'MapGuide' is being automatically disabled due to a series
of failures in the process(es) serving that application pool.
View this message in context: http://n2.nabble.com/Mapguide-Crashing-IIS-%28w3wp.exe%29-service-or-vice-Versa-tp2411452p2411452.html
