[mapguide-users] asp.net example of loading a webmapservice layer
stoff
mail at effing.org
Tue Mar 3 06:01:27 EST 2009
I have a new and an old problem :
First I am still looking for a solution about transparency
Do I have to configure it in the layerdefinition.xml AND in the called URL(
... ?service=wms&transparent=true)?
Second problem:
Loading of the wms layer works fine. But in the legend.aspx
BuildLayerDeifinitionData-Function there is an encoding-problem in the row
"doc.LoadXML(layerDefString). He finds a char code 65279 as first Charakter
.... strange, because loading of the layerdefinition works fine, and there
is no charakter like this in the xml-file ...
Is there a posibility to use explicitly UTF-8 Encoding within the mapguide
resource-classes?
Best regards,
Christoph
View this message in context: http://n2.nabble.com/asp.net-example-of-loading-a-webmapservice-layer-tp2328300p2414541.html
