[mapguide-users] asp.net example of loading a webmapservice layer
Stefan Dalakov s.dalakov at mapware.net
Tue Mar 3 07:01:51 EST 2009
First :
In my case it was enough to define it in the configuration file for the
WMS datasource
  <SchemaMapping provider="OSGeo.WMS.3.1" name="WMS"
xmlns="http://fdowms.osgeo.org/schemas">
    <complexType name="ByggType">
      <RasterDefinition name="Image">
        <Format>PNG</Format>
*        <Transparent>true</Transparent>
*        <BackgroundColor>0xFFFFFF</BackgroundColor>
        <Time>current</Time>
        <Elevation>0</Elevation>
        <SpatialContext>EPSG:32632</SpatialContext>
        <Layer name="VERANDA">
          <Style/>
        </Layer>
        <Layer name="TAKSPRANG">
          <Style/>
        </Layer>
Stefan Dalakov
stoff wrote:
> Hi,
> I have a new and an old problem :
> First I am still looking for a solution about transparency
> Do I have to configure it in the layerdefinition.xml AND in the called URL(
> ... ?service=wms&transparent=true)?
> Second problem:
> Loading of the wms layer works fine. But in the legend.aspx
> BuildLayerDeifinitionData-Function there is an encoding-problem in the row
> "doc.LoadXML(layerDefString). He finds a char code 65279 as first Charakter
> .... strange, because loading of the layerdefinition works fine, and there
> is no charakter like this in the xml-file ...
> Is there a posibility to use explicitly UTF-8 Encoding within the mapguide
> resource-classes?
> Best regards,
> Christoph
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090303/f1d9818c/attachment.html
