[mapguide-users] Polygon are not recorded in feature
Micho Gar michogar at gmail.com
Wed Mar 4 11:22:34 EST 2009
Thanks to all,
this the XML for this resource
<FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SHP</Provider>
<Parameter>
<Name>DefaultFileLocation</Name>
<Value>%MG_DATA_PATH_ALIAS[datos]%poligonos/zonas.shp</Value>
</Parameter>
<Parameter>
<Name>TemporaryFileLocation</Name>
<Value>%MG_DATA_PATH_ALIAS[datos]%temp/</Value>
</Parameter>
</FeatureSource>
I am still looking for that these days I could not get it.
2009/3/3 Ivan Milicevic <Ivan.Milicevic at supranet.hr>
>  MIcho,
> Please, open http://gis.supranet.hr/mapguide/mapagent/index.html click on
> Resource->GetResourceContent
> Maybe your feature source is set to rtead only. I had the same problem in
> past couple of days.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Micho Gar
> *Sent:* Monday, March 02, 2009 6:44 PM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Polygon are not recorded in feature
> Hi all,
> I have a code that should save the polygons in the feature source after
> using the Digitize. In principle I do not give any error, but when reviewing
> the shp the polygon don´t appear. I leave with you the code because I don´t
> see anything bad.
> MgUserInformation userInfo = new MgUserInformation(sessionId);
> MgSiteConnection siteConnection = new MgSiteConnection();
> siteConnection.Open(userInfo);
> MgResourceService resourceService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> MgFeatureService featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
> MgResourceIdentifier zonasFeatureId = new
> MgResourceIdentifier("Library://ConectorGPS/Datos/poligonosZonas.FeatureSource");
> MgFeatureCommandCollection zonasComando = new MgFeatureCommandCollection();
> //Abrimos el mapa
> MgMap mapa = new MgMap();
> mapa.Open(resourceService, mapName);
> //creamos la geometria
> MgGeometryFactory geometryFactory = new MgGeometryFactory();
> MgCoordinateCollection coordinateCollection = new MgCoordinateCollection();
> //MgLinearRingCollection interiorRingCollection = new
> MgLinearRingCollection();
> MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
> int count = xCollection.length;
> for(int i=0; i<count;i++)
>     Double x = Double.valueOf(xCollection[i]);
>     Double y = Double.valueOf(yCollection[i]);
>     MgCoordinate  coordinate = geometryFactory.CreateCoordinateXY(x,y);
>     coordinateCollection.Add(coordinate);
> MgLinearRing exteriorRing =
> geometryFactory.CreateLinearRing(coordinateCollection);
> MgPolygon polygon = geometryFactory.CreatePolygon(exteriorRing,null);
> MgByteReader geom = geometryReaderWriter.Write(polygon);
> //creamos una coleccion de propiedades y la insertamos
> MgPropertyCollection propiedades = new MgPropertyCollection();
> propiedades.Add(new MgGeometryProperty("Geometry", geom));
> propiedades.Add(new MgStringProperty("ID", "zona1"));
> zonasComando.Add(new MgInsertFeatures("zonasCapa", propiedades));
> featureService.UpdateFeatures(zonasFeatureId, zonasComando, false);
> //capturamos la capa para salvar el mapa y refrescar
> MgLayerBase zonasCapa = mapa.GetLayers().GetItem("zonasCapa");
> zonasCapa.SetVisible(true);
> zonasCapa.ForceRefresh();
> mapa.Save(resourceService);
> out.println("finish");
> Thanks
> # michogar
> # Analista Programador SIG
> # Ubuntu Linux Counter 462666
> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> peor... Si lo reproduces del derecho... ¡Se instala!."
> "It has a legend that if you play an original Windows Vista DVD backwards
> to hear Bill Gates Satanic chanting songs ... But that's not the worst ...
> If you play it right ... It installs!.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
# michogar
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090304/8a102cea/attachment.html
