[mapguide-users] Weblayouts Buil-in commands
Rui Daniro ruidaniro at hotmail.co.uk
Mon Mar 9 13:32:12 EDT 2009
Hi kenneth,
I have a OGR connection to my database. I can see my data with geographic
attributes but I can not see the other tables with non geographic data. How
can I acess them to use the data stored there? I would like to concanate
tables with geographic data with table with non geographic data to display
attributes stored in several tables. Can you help me with this?
Thanks
Rui
De: Kenneth Skovhede, GEOGRAF A/S (via Nabble)
[mailto:ml-user+64672-1645459268 at n2.nabble.com]
Enviada: 25 February 2009 11:54
Para: Rui Daniro
Assunto: Re: [mapguide-users] Weblayouts Buil-in commands
That depends on what you mean by "edit/customize".
If you mean "change the text" (eg, translate), you can do so with
MapGuide Maestro, or you can manually modify the underlying xml.
If you mean "alter functionality", you can look in the
"ajaxmappane.templ" file and modify the javascript there.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi all,
> I am usig MGE 2009 and I would like to know if it is possible
edit/costumize
> built-in commands. If yes, where and how can I get the code.
> Thanks in advance.
> Rui
mapguide-users mailing list
mapguide-users at ...
<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2383299&i=0>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
  _____
This email is a reply to your post @
http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2383299.html
You can reply by email or by visting the link above.
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.7/1982 - Release Date: 03/03/09
16:09:00
View this message in context: http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2450420.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090309/e43f4955/attachment.html
