[mapguide-users] Using non-geographics data (was: Weblayouts Buil-in commands)
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Mar 9 16:15:58 EDT 2009
You have to setup "Joins" for your datasources, and you can probably
find instructions for this if you search for it.
However, I have not managed to get joins working on anything but an
SDF/ODBC combination,
so I would recomend that you prepare your data to be "single-table" instead.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi kenneth,
> I have a OGR connection to my database. I can see my data with
> geographic attributes but I can not see the other tables with non
> geographic data. How can I acess them to use the data stored there? I
> would like to concanate tables with geographic data with table with
> non geographic data to display attributes stored in several tables.
> Can you help me with this?
> Thanks
> Rui
> *De:* Kenneth Skovhede, GEOGRAF A/S (via Nabble)
> [mailto:ml-user+64672-1645459268 at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2450420&i=0>]
> *Enviada:* 25 February 2009 11:54
> *Para:* Rui Daniro
> *Assunto:* Re: [mapguide-users] Weblayouts Buil-in commands
> That depends on what you mean by "edit/customize".
> If you mean "change the text" (eg, translate), you can do so with
> MapGuide Maestro, or you can manually modify the underlying xml.
> If you mean "alter functionality", you can look in the
> "ajaxmappane.templ" file and modify the javascript there.
> Rui Daniro skrev:
> > Hi all,
> > I am usig MGE 2009 and I would like to know if it is possible
> edit/costumize
> > built-in commands. If yes, where and how can I get the code.
> > Thanks in advance.
> > Rui
> mapguide-users mailing list
> mapguide-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2383299&i=0>
> This email is a reply to your post @
> http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2383299.html
> You can reply by email or by visting the link above.
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.0.237 / Virus Database: 270.11.7/1982 - Release Date:
> 03/03/09 16:09:00
> View this message in context: RE: [mapguide-users] Weblayouts Buil-in
> commands
> <http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2450420.html>
> Sent from the MapGuide Users mailing list archive
> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090309/c1f178a7/attachment.html
