[mapguide-users] Layer's selection Problem
    padmini godavarthi
    godavarthi.padmini at gmail.com
    Fri Mar 13 08:36:45 EDT 2009
can anyone help me to achieve layer selection in oracle package.
iam unable to find the solution ??????
Regards,
Padmini.
aniliht wrote:
> I'm also using a sql server 2008 and have 2 simple tables as follows:
> Drawing
> - DrawingID (PK, int, not null)
> - DrawingName (varchar(50))
> Point
> - PointID (PK, int, not null)
> - DrawingID (FK, int, not null)
> - Name (varchar(50))
> - Point (geography, not null)
> There is one row in each table,  the geography instance is in SRID 4326
> (WGS 84).  The item displays properly but I can't select it no matter
> what.
> I'm using the windows install of Mapguide 2.0.2:
> MgServerSetup-2.0.2.3011.exe.  It did not have the SQL Server Spatial
> provider bundled.  So I installed the
> fdosqlserverspatial-3.3.0_win32.tar.gz which is SQL Server Spatial BETA 1.
> I chose this because the dll version of the bundled FDO.dll that the
> MgServerSetup installed was 3.3.0.3901.
> Do you know if the BETA 1 version of the SQL Server Spatial provider
> doesn't support selection on layers?
> What version of MapGuide, FDO, SQL Server Spatial Provider releases work
> to be able to select points on a SQL layer?
> Is it ok to install the latest version of FDO (which is 3.3.2) into the
> C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO directory,
> overwritting the contents that the MgServerSetup placed?
> The release notes for MG 2.0.2 says: "MGOS 2.0.2 is compatible with FDO
> 3.3.1 but the version packaged with the installers is actually a newer
> version."  But the version of FDO in the Bin directory appears to be
> 3.3.0.3901.
> Thanks for any clues you can provide.
> miansi wrote:
>> I have exactly the same behaviour for SQL 2008.
>> I do not know if this is applicable for Oracle, but for SQL
>> 1. You have to have Primary Key (clustered) on the table you want to show
>> on the layer
>> 2. PK has to be int
>> 3. You have to create spatial index on the spatial column
>> 4. As soon as you will try to add JOINS to your database view (if you
>> trying to show layer off View) - you will lose selection functionality. I
>> am fighting with this one for week already.
>> Hope that will help
>> padmini godavarthi wrote:
>>> Hi,
>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>> I have created a package using Oracle "OSGEO FDO provider for Oracle"
>>> and Mapguide Maestro.
>>> but while seeing the map by"Show in browser" the layers are does not
>>> selecting on map and the properties is not displaying even after i
>>> checked the option "Features on layer are selectable" in the map
>>> resource.
>>> Is anything i did wrong?
>>> Can u plz tell me the solution?
>>> Thanks and Regards,
>>> Padmini.
View this message in context: http://n2.nabble.com/Layer%27s-selection-Problem-tp2352146p2473167.html
