[mapguide-users] Errors with mapguide svn checkout
Jonathan Manafi
jonathan.manafi at cctechnol.com
Fri Mar 13 12:38:49 EDT 2009
Thanks for the tip.
It did work for me to get the mapguide trunk downloaded.
However, while trying to build FDO in order to build mapguide, I ran
into some MSBuild errors. Is Visual Studio 2008 required to properly
build everything for the new release?
Kenneth Skovhede, GEOGRAF A/S wrote:
> I get this all the time as well.
> Just keep the folder after it breaks, then right click it, and select
> "Tortoise SVN" -> "Update".
> Repeat until you get no error messages. TortoiseSVN will automatically
> detect what files are updated, and which are missing.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> manafi skrev:
>> I'm not entirely sure I am going about this correctly, but I have
>> been getting errors every time I try to do an svn-checkout on the
>> mapguide repository.
>> * I downloaded tortoiseSVN
>> * I created a folder and did right-click, 'svn checkout...'
>> * I pointed the url to http://svn.osgeo.org/mapguide/trunk/MgDev
>> And files began downloading to my local folder. The progress varies,
>> but after downloading 50-100MB, I get an error stating
>> "REPORT of '/mapguide/!svn/vcc/default': Could not read chunk
>> and just this last attempt, I also got
>> "was closed by server (http://svn.osgeo.org)"
>> I suspect that I'm doing something wrong, but is it possible that
>> there is a problem with svn checkouts?
>> Or maybe does anyone have some advice for getting this to work? I'm
>> not very versed in svn usage.
>> My OS is Windows XP
>> Thanks.
>> View this message in context: Errors with mapguide svn checkout
>> <http://n2.nabble.com/Errors-with-mapguide-svn-checkout-tp2468295p2468295.html>
>> Sent from the MapGuide Users mailing list archive
>> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090313/72fac2bf/attachment.html
