[mapguide-users] Errors with mapguide svn checkout
Jackie Ng
jumpinjackie at gmail.com
Fri Mar 13 13:21:47 EDT 2009
Yes you need VS 2008 to build both MapGuide and FDO.
If you want to save time, skip building FDO and just drop the binaries into
Oem\FDO
- Jackie
manafi wrote:
> Thanks for the tip.
> It did work for me to get the mapguide trunk downloaded.
> However, while trying to build FDO in order to build mapguide, I ran
> into some MSBuild errors. Is Visual Studio 2008 required to properly
> build everything for the new release?
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I get this all the time as well.
>> Just keep the folder after it breaks, then right click it, and select
>> "Tortoise SVN" -> "Update".
>> Repeat until you get no error messages. TortoiseSVN will automatically
>> detect what files are updated, and which are missing.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> manafi skrev:
>>> I'm not entirely sure I am going about this correctly, but I have
>>> been getting errors every time I try to do an svn-checkout on the
>>> mapguide repository.
>>> * I downloaded tortoiseSVN
>>> * I created a folder and did right-click, 'svn checkout...'
>>> * I pointed the url to http://svn.osgeo.org/mapguide/trunk/MgDev
>>> And files began downloading to my local folder. The progress varies,
>>> but after downloading 50-100MB, I get an error stating
>>> "REPORT of '/mapguide/!svn/vcc/default': Could not read chunk
>>> and just this last attempt, I also got
>>> "was closed by server (http://svn.osgeo.org)"
>>> I suspect that I'm doing something wrong, but is it possible that
>>> there is a problem with svn checkouts?
>>> Or maybe does anyone have some advice for getting this to work? I'm
>>> not very versed in svn usage.
>>> My OS is Windows XP
>>> Thanks.
>>> View this message in context: Errors with mapguide svn checkout
>>> <http://n2.nabble.com/Errors-with-mapguide-svn-checkout-tp2468295p2468295.html>
>>> Sent from the MapGuide Users mailing list archive
>>> <http://n2.nabble.com/MapGuide-Users-f1803227.html> at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Errors-with-mapguide-svn-checkout-tp2468295p2474705.html
