[mapguide-users] SQL 2008 Geographic data type can't be selected
Rodolfo Moreno
rmoreno at voxiva.com
Fri Mar 13 15:03:08 EDT 2009
In sql 2008 there are two types of spatial data: Geometry (flat Earth model)
and Geography (ellipsoidal model).
The issue is with geography data type. The features are displayed but these
can't be selected.
Regards,
Martin Morrison wrote:
> Maybe I am misunderstanding what the issue is. Early on you stated:
> " for the case of geographic data type the
> selection of the features is not possible."
> So what exactly is the issue that you are having?
> Martin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Friday, March 13, 2009 11:18 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] SQL 2008 Geographic data type can't be
> selected
> That's right. geometry type in sql 2008 is working correctly. It means you
> can display and select the features.
>> I just want to note that I am using SQL 2008 to display geometry without
>> any issues...
>> Martin
>> Moreno
>> Sent: Friday, March 13, 2009 10:55 AM
>> selected
>> Hi all,
>> I was reviewing others theards with relation to it.
>> http://n2.nabble.com/Layer%27s-selection-Problem-td2352146.html
>> It seems to be an issue with geography data type in sql 2008. I would
>> like
>> to post a ticket but I don't know exactly in where is the error in
>> mapguide
>> or FDO.
>> Any opinion?
>> Regards
>> Rodolfo Moreno wrote:
>>> Yes, my table has primary key (as integer) and spatial index with
>>> geographic grid.
>>> Regards,
>>> Dave Wilson wrote:
>>>> Can you ensure your table has a primary key? I'm pretty sure it's
>>>> required.
>>>> Dave
>>>> Moreno
>>>> Sent: Friday, March 06, 2009 4:01 PM
>>>> selected
>>>> Hi Andrei,
>>>> sorry for my delay.
>>>> I have created a new sql table with geography sql type and I added two
>>>> simple polygons.
>>>> here is my sql script:
>>>> insert into test1
>>>> VALUES (1,geography::STGeomFromText('POLYGON ((0 0 ,1 0,1 1 , 0 1, 0 0
>>>> 4326) )
>>>> insert into test1
>>>> VALUES (2,geography::STGeomFromText('POLYGON ((1 1 ,3 1,2 3 , 1 1 ))',
>>>> 4326)
>>>> Next I have displayed the features with the ajax viewer of the MGOS (I
>>>> am
>>>> using 2.0.1 version) and the result is the same.
>>>> It means that the features are shown but these can't be selected.
>>>> I guess that it is an issue of MGOS. have you ever had success with it?
>>>> Regards,
>>>>> Thanks Andrei, I am goin to try your suggestion.
>>>>> miansi wrote:
>>>>>> Hello Rodolfo,
>>>>>> Make sure you set SRID while populating SQL:
>>>>>> , [Geo] = GEOMETRY::STGeomFromText([import].[Geo], @SRID)
>>>>>> Base on your map (WGS 84) your SRID should be something like 4326
>>>>>> Regards,
>>>>>> Andrei
>>>>>> Moreno
>>>>>> Sent: Monday, March 02, 2009 9:15 AM
>>>>>> Subject: [mapguide-users] SQL 2008 Geographic data type can't be
>>>>>> selected
>>>>>> I have could select features from geometric data type (sql 2008 as
>>>>>> data
>>>>>> source) however, for the case of geographic data type the selection
>>>>>> of
>>>>>> the
>>>>>> The error shown in the log is: "sys.geometry is incompatible with
>>>>>> sys.geography"
>>>>>> The map that contains this layer is set as WGS 84.
>>>>>> any help will be appreciated, thanks
>>>>>> Rodolfo Moreno
>>>>>> CivilEng
>>>>>> View this message in context:
>>>>>> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-t
>>>>>> p2410036p2410036.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> ----Notice Regarding Confidentiality----
>>>>>> This email, including any and all attachments, (this "Email") is
>>>>>> intended
>>>>>> only for the party to whom it is addressed and may contain
>>>>>> information
>>>>>> that is confidential or privileged. Sierra Systems Group Inc. and
>>>>>> its
>>>>>> affiliates accept no responsibility for any loss or damage suffered
>>>>>> by
>>>>>> any person resulting from any unauthorized use of or reliance upon
>>>>>> this
>>>>>> Email. If you are not the intended recipient, you are hereby
>>>>>> notified
>>>>>> that any dissemination, copying or other use of this Email is
>>>>>> prohibited.
>>>>>> Please notify us of the error in communication by return email and
>>>>>> destroy all copies of this Email. Thank you.
>>>> Rodolfo Moreno
>>>> CivilEng
>>>> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2438599.html
>> Rodolfo Moreno
>> CivilEng
>> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2473836.html
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2473971.html
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/SQL-2008-Geographic-data-type-can%27t-be-selected-tp2410036p2475222.html
