[mapguide-users] Unable to connect to MGOS via MapGuide
Studio/.NETAPI
prbabu
prbabu at openspatial.com.au
Sun Mar 15 20:17:58 EDT 2009
Nope. The IP address is fixed on the server.
Regards,
Praveen
Ivan Milicevic wrote:
> Is your server change IP in the meantime?
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Praveen
> Rajendra Babu
> Sent: Saturday, March 14, 2009 2:14 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Unable to connect to MGOS via MapGuide
> Studio/.NETAPI
> Hi,
> If I leave the MGOS server (version 2.0.2.3011) idle for a
> while(like overnight) and then try to connect to server via Maestro, I
> get the message.
> ************************* Maestro pop-up window message
> Maestro
> Failed to log on because: Failed to connect, please check network
> connection and login information.
> Extended error info: Failed to connect, perhaps session is expired?
> Extended error info: Invalid server token recieved: <html><head><META
> http-equiv="Content-Type" content="text/html;
> charset=UTF-8"><title>osenlighten -
> /mapguide/</title></head><body><H1>osenlighten - /mapguide/</H1><hr>
> <pre> / [To Parent Directory] <br><br> Monday, December
> 22, 2008 3:25 PM <dir> /mapguide/data/ data <br> Monday,
> December 22, 2008 3:32
> PM <dir> /mapguide/dotnetviewersample/ dotnetviewersample
> <br>
> Tuesday, January 20, 2009 12:02 PM <dir> /mapguide/fusion/
> fusion <br> Tuesday, January 20, 2009
> 11:54 AM 1847872 /mapguide/fusion-1.1.0.zip fusion-1.1.0.zip <br>
> Thursday,
> January 08, 2009 9:46 AM <dir> /mapguide/fusion-old/
> fusion-old <br> Monday, December 22,
> 2008 3:25 PM <dir> /mapguide/localized/ localized <br>
> 2008 3:25 PM <dir> /mapguide/mapadmin/ mapadmin <br>
> Monday, December 22, 2008
> 3:25 PM <dir> /mapguide/mapagent/ mapagent <br> Wednesday,
> January 21, 2009
> 6:08 PM <dir> /mapguide/mapviewernet/ mapviewernet <br>
> Tuesday, December
> 23, 2008 12:24 PM <dir> /mapguide/mapviewerphp/ mapviewerphp
> 22, 2008 3:25 PM <dir> /mapguide/nad/ nad <br> Friday,
> January 30, 2009 2:31 PM
> <dir> /mapguide/OpenLayers-2.7/ OpenLayers-2.7 <br>
> Friday, January 30, 2009 1:52 PM <dir>
> /mapguide/phpviewersample/ phpviewersample <br> Monday,
> December 22, 2008 3:25 PM <dir> /mapguide/schemareport/
> schemareport <br> Monday, December
> 22, 2008 3:25 PM <dir> /mapguide/stdicons/ stdicons <br>
> 3:25 PM <dir> /mapguide/viewerfiles/ viewerfiles <br>
> Monday, December
> 22, 2008 3:27 PM 8245 /mapguide/webconfig.ini webconfig.ini <br>
> Monday, December
> 22, 2008 3:25 PM <dir> /mapguide/webstudio/ webstudio
> <br></pre><hr></body></html>
> OK
> If I try to connect to the MGOS server via .NET API code, I get the
> below message:
> <html>
> <head>
> <title>MgConnectionFailedException</title>
> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
> </head>
> <body>
> <h2>Cannot establish connection.</h2>
> Exception occurred in method MgServerConnection.Open at line 106 in file
> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidec
> ommon\Services/ServerConnection.cpp
> </body>
> </html>
> To get things back to normal, I re-start WWW services in Windows
> Server 2003. Am I missing something in the set-up or configuration of
> MGOS or IIS Server? FYKI, we are using IIS Server v6.0.
> Any comments/suggestions would be highly appreciated.
> Thanks and regards,
> Praveen
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-tp2476671p2483503.html
