[mapguide-users] Unable to connect to MGOS via MapGuide Studio/.NET API
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Mar 16 04:08:21 EDT 2009
That look really odd.
What happens is that Maestro connects to
http://localhost/mapguide
but this is really mapped to
http://localhost/mapguide/mapagent/mapagent.fcgi
There is some logic inside Maestro (line 1027 in HttpServerConnection.cs),
that maps from the short form to the long form.
If the short form fails, the long form is attempted.
If the long form fails, the exception for the short for is thrown,
which is likely what happens here.
I have no idea why an IIS restart would fix connection problems with
MapGuide.
Regards, Kenneth Skovhede, GEOGRAF A/S
Praveen Rajendra Babu skrev:
> Hi,
>     If I leave the MGOS server (version 2.0.2.3011) idle for a
> while(like overnight) and then try to connect to server via Maestro, I
> get the message.
> ************************* Maestro pop-up window message
> Maestro
> Failed to log on because: Failed to connect, please check network
> connection and login information.
> Extended error info: Failed to connect, perhaps session is expired?
> Extended error info: Invalid server token recieved: <html><head><META
> http-equiv="Content-Type" content="text/html;
> charset=UTF-8"><title>osenlighten -
> /mapguide/</title></head><body><H1>osenlighten - /mapguide/</H1><hr>
> <pre><A HREF="/">[To Parent Directory]</A><br><br>    Monday, December
> 22, 2008  3:25 PM        &lt;dir&gt; <A
> HREF="/mapguide/data/">data</A><br>    Monday, December 22, 2008  3:32
> PM        &lt;dir&gt; <A
> HREF="/mapguide/dotnetviewersample/">dotnetviewersample</A><br>
> Tuesday, January 20, 2009 12:02 PM        &lt;dir&gt; <A
> HREF="/mapguide/fusion/">fusion</A><br>    Tuesday, January 20, 2009
> 11:54 AM      1847872 <A
> HREF="/mapguide/fusion-1.1.0.zip">fusion-1.1.0.zip</A><br>   Thursday,
> January 08, 2009  9:46 AM        &lt;dir&gt; <A
> HREF="/mapguide/fusion-old/">fusion-old</A><br>    Monday, December
> HREF="/mapguide/localized/">localized</A><br>    Monday, December 22,
> HREF="/mapguide/mapadmin/">mapadmin</A><br>    Monday, December 22,
> HREF="/mapguide/mapagent/">mapagent</A><br>  Wednesday, January 21,
> 2009  6:08 PM        &lt;dir&gt; <A
> HREF="/mapguide/mapviewernet/">mapviewernet</A><br>   Tuesday,
> December 23, 2008 12:24 PM        &lt;dir&gt; <A
> HREF="/mapguide/mapviewerphp/">mapviewerphp</A><br>    Monday,
> December 22, 2008  3:25 PM        &lt;dir&gt; <A
> HREF="/mapguide/nad/">nad</A><br>     Friday, January 30, 2009  2:31
> PM        &lt;dir&gt; <A
> HREF="/mapguide/OpenLayers-2.7/">OpenLayers-2.7</A><br>     Friday,
> January 30, 2009  1:52 PM        &lt;dir&gt; <A
> HREF="/mapguide/phpviewersample/">phpviewersample</A><br>    Monday,
> HREF="/mapguide/schemareport/">schemareport</A><br>    Monday,
> HREF="/mapguide/stdicons/">stdicons</A><br>    Monday, December 22,
> HREF="/mapguide/viewerfiles/">viewerfiles</A><br>    Monday, December
> 22, 2008  3:27 PM         8245 <A
> HREF="/mapguide/webconfig.ini">webconfig.ini</A><br>    Monday,
> HREF="/mapguide/webstudio/">webstudio</A><br></pre><hr></body></html>
> OK
> If I try to connect to the MGOS server via .NET API code, I get the
> below message:
> <html>
> <head>
> <title>MgConnectionFailedException</title>
> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
> </head>
> <body>
> <h2>Cannot establish connection.</h2>
> Exception occurred in method MgServerConnection.Open at line 106 in
> file
> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidecommon\Services/ServerConnection.cpp
> </body>
> </html>
>    To get things back to normal, I re-start WWW services in Windows
> Server 2003. Am I missing something in the set-up or configuration of
> MGOS or IIS Server?  FYKI, we are using IIS Server v6.0.
> Any comments/suggestions would be highly appreciated.
> Thanks and regards,
> Praveen
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090316/3ddf9f12/attachment.html
