[mapguide-users] Unable to connect to MGOS via MapGuide
Studio/.NET API
prbabu
prbabu at openspatial.com.au
Mon Mar 16 19:38:14 EDT 2009
I am not sure either. What I did is not allow the worker process to recycle
within IIS, even when idle and also created a separate application pool for
mapguide itself. This morning, I am able to login/see the map without any
re-starts. Would not conclude this as the solution yet - needs more
investigation.
Thanks for your response, though.
Regards,
Praveen
Kenneth Skovhede, GEOGRAF A/S wrote:
> That look really odd.
> What happens is that Maestro connects to
> http://localhost/mapguide
> but this is really mapped to
> http://localhost/mapguide/mapagent/mapagent.fcgi
> There is some logic inside Maestro (line 1027 in HttpServerConnection.cs),
> that maps from the short form to the long form.
> If the short form fails, the long form is attempted.
> If the long form fails, the exception for the short for is thrown,
> which is likely what happens here.
> I have no idea why an IIS restart would fix connection problems with
> MapGuide.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Praveen Rajendra Babu skrev:
>> Hi,
>> If I leave the MGOS server (version 2.0.2.3011) idle for a
>> while(like overnight) and then try to connect to server via Maestro, I
>> get the message.
>> ************************* Maestro pop-up window message
>> Maestro
>> Failed to log on because: Failed to connect, please check network
>> connection and login information.
>> Extended error info: Failed to connect, perhaps session is expired?
>> Extended error info: Invalid server token recieved: <html><head><META
>> http-equiv="Content-Type" content="text/html;
>> charset=UTF-8"><title>osenlighten -
>> /mapguide/</title></head><body><H1>osenlighten - /mapguide/</H1><hr>
>> <pre> / [To Parent Directory] <br><br> Monday, December
>> 22, 2008 3:25 PM <dir> HREF="/mapguide/data/">data <br>
>> Monday, December 22, 2008 3:32
>> PM <dir>
>> HREF="/mapguide/dotnetviewersample/">dotnetviewersample <br>
>> Tuesday, January 20, 2009 12:02 PM <dir>
>> HREF="/mapguide/fusion/">fusion <br> Tuesday, January 20, 2009
>> 11:54 AM 1847872
>> HREF="/mapguide/fusion-1.1.0.zip">fusion-1.1.0.zip <br> Thursday,
>> January 08, 2009 9:46 AM <dir>
>> HREF="/mapguide/fusion-old/">fusion-old <br> Monday, December
>> HREF="/mapguide/localized/">localized <br> Monday, December 22,
>> 2008 3:25 PM <dir> HREF="/mapguide/mapadmin/">mapadmin
>> 2008 3:25 PM <dir> HREF="/mapguide/mapagent/">mapagent
>> <br> Wednesday, January 21,
>> 2009 6:08 PM <dir>
>> HREF="/mapguide/mapviewernet/">mapviewernet <br> Tuesday,
>> December 23, 2008 12:24 PM <dir>
>> HREF="/mapguide/mapviewerphp/">mapviewerphp <br> Monday,
>> December 22, 2008 3:25 PM <dir> HREF="/mapguide/nad/">nad
>> <br> Friday, January 30, 2009 2:31
>> PM <dir> HREF="/mapguide/OpenLayers-2.7/">OpenLayers-2.7
>> <br> Friday,
>> January 30, 2009 1:52 PM <dir>
>> HREF="/mapguide/phpviewersample/">phpviewersample <br> Monday,
>> HREF="/mapguide/schemareport/">schemareport <br> Monday,
>> HREF="/mapguide/stdicons/">stdicons <br> Monday, December 22,
>> 2008 3:25 PM <dir>
>> HREF="/mapguide/viewerfiles/">viewerfiles <br> Monday, December
>> 22, 2008 3:27 PM 8245
>> HREF="/mapguide/webconfig.ini">webconfig.ini <br> Monday,
>> HREF="/mapguide/webstudio/">webstudio <br></pre><hr></body></html>
>> OK
>> If I try to connect to the MGOS server via .NET API code, I get the
>> below message:
>> <html>
>> <head>
>> <title>MgConnectionFailedException</title>
>> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
>> </head>
>> <body>
>> <h2>Cannot establish connection.</h2>
>> Exception occurred in method MgServerConnection.Open at line 106 in
>> file
>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidecommon\Services/ServerConnection.cpp
>> </body>
>> </html>
>> To get things back to normal, I re-start WWW services in Windows
>> Server 2003. Am I missing something in the set-up or configuration of
>> MGOS or IIS Server? FYKI, we are using IIS Server v6.0.
>> Any comments/suggestions would be highly appreciated.
>> Thanks and regards,
>> Praveen
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-tp2476671p2489081.html
