[mapguide-users] Unable to connect to MGOS via MapGuide
Studio/.NET API
Rui Daniro
ruidaniro at hotmail.co.uk
Tue Mar 17 07:57:05 EDT 2009
Hi all,
I am having the same problem, I left the MGOS server (version 2.0.2.3011)
idle for a while(like overnight) and then try to connect to server via
Maestro, I get the sames messages, the only difference is that I am using
apache instead IIS. I tried to restart apache and nothing changed.
prbabu wrote:
> I am not sure either. What I did is not allow the worker process to
> recycle within IIS, even when idle and also created a separate application
> pool for mapguide itself. This morning, I am able to login/see the map
> without any re-starts. Would not conclude this as the solution yet - needs
> more investigation.
> Thanks for your response, though.
> Regards,
> Praveen
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> That look really odd.
>> What happens is that Maestro connects to
>> http://localhost/mapguide
>> but this is really mapped to
>> http://localhost/mapguide/mapagent/mapagent.fcgi
>> There is some logic inside Maestro (line 1027 in
>> HttpServerConnection.cs),
>> that maps from the short form to the long form.
>> If the short form fails, the long form is attempted.
>> If the long form fails, the exception for the short for is thrown,
>> which is likely what happens here.
>> I have no idea why an IIS restart would fix connection problems with
>> MapGuide.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Praveen Rajendra Babu skrev:
>>> Hi,
>>> If I leave the MGOS server (version 2.0.2.3011) idle for a
>>> while(like overnight) and then try to connect to server via Maestro, I
>>> get the message.
>>> ************************* Maestro pop-up window message
>>> Maestro
>>> Failed to log on because: Failed to connect, please check network
>>> connection and login information.
>>> Extended error info: Failed to connect, perhaps session is expired?
>>> Extended error info: Invalid server token recieved: <html><head><META
>>> http-equiv="Content-Type" content="text/html;
>>> charset=UTF-8"><title>osenlighten -
>>> /mapguide/</title></head><body><H1>osenlighten - /mapguide/</H1><hr>
>>> <pre> / [To Parent Directory] <br><br> Monday, December
>>> 22, 2008 3:25 PM <dir> HREF="/mapguide/data/">data <br>
>>> Monday, December 22, 2008 3:32
>>> PM <dir>
>>> HREF="/mapguide/dotnetviewersample/">dotnetviewersample <br>
>>> Tuesday, January 20, 2009 12:02 PM <dir>
>>> HREF="/mapguide/fusion/">fusion <br> Tuesday, January 20, 2009
>>> 11:54 AM 1847872
>>> HREF="/mapguide/fusion-1.1.0.zip">fusion-1.1.0.zip <br> Thursday,
>>> January 08, 2009 9:46 AM <dir>
>>> HREF="/mapguide/fusion-old/">fusion-old <br> Monday, December
>>> HREF="/mapguide/localized/">localized <br> Monday, December 22,
>>> 2008 3:25 PM <dir> HREF="/mapguide/mapadmin/">mapadmin
>>> 2008 3:25 PM <dir> HREF="/mapguide/mapagent/">mapagent
>>> <br> Wednesday, January 21,
>>> 2009 6:08 PM <dir>
>>> HREF="/mapguide/mapviewernet/">mapviewernet <br> Tuesday,
>>> December 23, 2008 12:24 PM <dir>
>>> HREF="/mapguide/mapviewerphp/">mapviewerphp <br> Monday,
>>> December 22, 2008 3:25 PM <dir>
>>> HREF="/mapguide/nad/">nad <br> Friday, January 30, 2009 2:31
>>> PM <dir> HREF="/mapguide/OpenLayers-2.7/">OpenLayers-2.7
>>> <br> Friday,
>>> January 30, 2009 1:52 PM <dir>
>>> HREF="/mapguide/phpviewersample/">phpviewersample <br> Monday,
>>> HREF="/mapguide/schemareport/">schemareport <br> Monday,
>>> HREF="/mapguide/stdicons/">stdicons <br> Monday, December 22,
>>> 2008 3:25 PM <dir>
>>> HREF="/mapguide/viewerfiles/">viewerfiles <br> Monday, December
>>> 22, 2008 3:27 PM 8245
>>> HREF="/mapguide/webconfig.ini">webconfig.ini <br> Monday,
>>> HREF="/mapguide/webstudio/">webstudio <br></pre><hr></body></html>
>>> OK
>>> If I try to connect to the MGOS server via .NET API code, I get the
>>> below message:
>>> <html>
>>> <head>
>>> <title>MgConnectionFailedException</title>
>>> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
>>> </head>
>>> <body>
>>> <h2>Cannot establish connection.</h2>
>>> Exception occurred in method MgServerConnection.Open at line 106 in
>>> file
>>> d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidecommon\Services/ServerConnection.cpp
>>> </body>
>>> </html>
>>> To get things back to normal, I re-start WWW services in Windows
>>> Server 2003. Am I missing something in the set-up or configuration of
>>> MGOS or IIS Server? FYKI, we are using IIS Server v6.0.
>>> Any comments/suggestions would be highly appreciated.
>>> Thanks and regards,
>>> Praveen
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Unable-to-connect-to-MGOS-via-MapGuide-Studio-.NET-API-tp2476671p2490925.html
