[mapguide-users] Layer's selection Problem
padmini godavarthi
godavarthi.padmini at gmail.com
Tue Mar 17 00:54:40 EDT 2009
Thank u very much for your reply.
i will check it out.
Regards,
Padmini.
miansi wrote:
> Hello,
> Sorry for late responce.
> Everything should work. You have to check few things:
> 1. You have to have UNIQUE NON CLUSTERED INDEX on PointID column
> 2. You have to have Spatial INDEX on Point column
> 3. Map also have to use SRID 4326 (WGS 84)
> 4. Check on the Map that layer marked as selectable - it is not by default
> 5. If you using Views - No JOINS - it is confirmed bug. As soon as you
> introduce JOINS in Views - you will loose selection functionality
> It should work,
> Andrei
> aniliht wrote:
>> I'm also using a sql server 2008 and have 2 simple tables as follows:
>> Drawing
>> - DrawingID (PK, int, not null)
>> - DrawingName (varchar(50))
>> Point
>> - PointID (PK, int, not null)
>> - DrawingID (FK, int, not null)
>> - Name (varchar(50))
>> - Point (geography, not null)
>> There is one row in each table, the geography instance is in SRID 4326
>> (WGS 84). The item displays properly but I can't select it no matter
>> what.
>> I'm using the windows install of Mapguide 2.0.2:
>> MgServerSetup-2.0.2.3011.exe. It did not have the SQL Server Spatial
>> provider bundled. So I installed the
>> fdosqlserverspatial-3.3.0_win32.tar.gz which is SQL Server Spatial BETA
>> 1. I chose this because the dll version of the bundled FDO.dll that the
>> MgServerSetup installed was 3.3.0.3901.
>> Do you know if the BETA 1 version of the SQL Server Spatial provider
>> doesn't support selection on layers?
>> What version of MapGuide, FDO, SQL Server Spatial Provider releases work
>> to be able to select points on a SQL layer?
>> Is it ok to install the latest version of FDO (which is 3.3.2) into the
>> C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO directory,
>> overwritting the contents that the MgServerSetup placed?
>> The release notes for MG 2.0.2 says: "MGOS 2.0.2 is compatible with FDO
>> 3.3.1 but the version packaged with the installers is actually a newer
>> version." But the version of FDO in the Bin directory appears to be
>> 3.3.0.3901.
>> Thanks for any clues you can provide.
>> miansi wrote:
>>> I have exactly the same behaviour for SQL 2008.
>>> I do not know if this is applicable for Oracle, but for SQL
>>> 1. You have to have Primary Key (clustered) on the table you want to
>>> show on the layer
>>> 2. PK has to be int
>>> 3. You have to create spatial index on the spatial column
>>> 4. As soon as you will try to add JOINS to your database view (if you
>>> trying to show layer off View) - you will lose selection functionality.
>>> I am fighting with this one for week already.
>>> Hope that will help
>>> padmini godavarthi wrote:
>>>> Hi,
>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>> I have created a package using Oracle "OSGEO FDO provider for Oracle"
>>>> and Mapguide Maestro.
>>>> but while seeing the map by"Show in browser" the layers are does not
>>>> selecting on map and the properties is not displaying even after i
>>>> checked the option "Features on layer are selectable" in the map
>>>> resource.
>>>> Is anything i did wrong?
>>>> Can u plz tell me the solution?
>>>> Thanks and Regards,
>>>> Padmini.
View this message in context: http://n2.nabble.com/Layer%27s-selection-Problem-tp2352146p2489737.html
