[mapguide-users] Layer's selection Problem
miansi AndreiSinelnikov at SierraSystems.com
Tue Mar 17 13:00:43 EDT 2009
You do not confirm one more thing:
Did you check that your map using same coordinate system as records SRID?
http://n2.nabble.com/file/n2492571/nabble.png
padmini godavarthi wrote:
> Hi,
> Thank u very much for your reply.
> i have a table with the following columns
>  Name                                      Null?    Type
>  OBJECTID                                  NOT NULL NUMBER(38)
>  PROP_ID                                            VARCHAR2(50)
>  GIS_SHEET_IDV                                      VARCHAR2(50)
>  PROP_RMKS                                          VARCHAR2(50)
>  PROP_TMPD                                          DATE
>  SHAPE                                              MDSYS.SDO_GEOMETRY
>  SE_ANNO_CAD_DATA                                   BLOB
>  PROP_IMG                                           BLOB
>  AREA                                               NUMBER(38,8)
> 1) Here Shape is the spatial column and PROP_ID is unique int his table
> 2) i have a spatial index for the shape column
> 3) and in this shape column srid is 32643 for all the shapes
> 4) and the layer is checked as selectable
> 5) iam not using views . i have taken a table for displaying map
> But the problem is same .iam unable to select the layer on the viewer
> and the layer length came as '0'.iam unable to get
> it.
> iam sending my screen shot
> can u plz tell me the solution
>  http://n2.nabble.com/file/n2489737/map.jpeg
>  http://n2.nabble.com/file/n2489737/map1.jpeg
> Regards,
> Padmini.
> miansi wrote:
>> Hello,
>> Sorry for late responce.
>> Everything should work. You have to check few things:
>> 1. You have to have UNIQUE NON CLUSTERED INDEX on PointID column
>> 2. You have to have Spatial INDEX on Point column
>> 3. Map also have to use SRID 4326 (WGS 84)
>> 4. Check on the Map that layer marked as selectable - it is not by
>> default
>> 5. If you using Views - No JOINS - it is confirmed bug. As soon as you
>> introduce JOINS in Views - you will loose selection functionality
>> It should work,
>> Andrei
>> aniliht wrote:
>>> I'm also using a sql server 2008 and have 2 simple tables as follows:
>>> Drawing
>>> - DrawingID (PK, int, not null)
>>> - DrawingName (varchar(50))
>>> Point
>>> - PointID (PK, int, not null)
>>> - DrawingID (FK, int, not null)
>>> - Name (varchar(50))
>>> - Point (geography, not null)
>>> There is one row in each table,  the geography instance is in SRID 4326
>>> (WGS 84).  The item displays properly but I can't select it no matter
>>> what.
>>> I'm using the windows install of Mapguide 2.0.2:
>>> MgServerSetup-2.0.2.3011.exe.  It did not have the SQL Server Spatial
>>> provider bundled.  So I installed the
>>> fdosqlserverspatial-3.3.0_win32.tar.gz which is SQL Server Spatial BETA
>>> 1.  I chose this because the dll version of the bundled FDO.dll that the
>>> MgServerSetup installed was 3.3.0.3901.
>>> Do you know if the BETA 1 version of the SQL Server Spatial provider
>>> doesn't support selection on layers?
>>> What version of MapGuide, FDO, SQL Server Spatial Provider releases work
>>> to be able to select points on a SQL layer?
>>> Is it ok to install the latest version of FDO (which is 3.3.2) into the
>>> C:\Program Files\MapGuideOpenSource2.0\Server\Bin\FDO directory,
>>> overwritting the contents that the MgServerSetup placed?
>>> The release notes for MG 2.0.2 says: "MGOS 2.0.2 is compatible with FDO
>>> 3.3.1 but the version packaged with the installers is actually a newer
>>> version."  But the version of FDO in the Bin directory appears to be
>>> 3.3.0.3901.
>>> Thanks for any clues you can provide.
>>> miansi wrote:
>>>> I have exactly the same behaviour for SQL 2008.
>>>> I do not know if this is applicable for Oracle, but for SQL
>>>> 1. You have to have Primary Key (clustered) on the table you want to
>>>> show on the layer
>>>> 2. PK has to be int
>>>> 3. You have to create spatial index on the spatial column
>>>> 4. As soon as you will try to add JOINS to your database view (if you
>>>> trying to show layer off View) - you will lose selection functionality.
>>>> I am fighting with this one for week already.
>>>> Hope that will help
>>>>> Hi,
>>>>> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
>>>>> I have created a package using Oracle "OSGEO FDO provider for Oracle"
>>>>> and Mapguide Maestro.
>>>>> but while seeing the map by"Show in browser" the layers are does not
>>>>> selecting on map and the properties is not displaying even after i
>>>>> checked the option "Features on layer are selectable" in the map
>>>>> resource.
>>>>> Is anything i did wrong?
>>>>> Can u plz tell me the solution?
>>>>> Thanks and Regards,
>>>>> Padmini.
View this message in context: http://n2.nabble.com/Layer%27s-selection-Problem-tp2352146p2492571.html
