[mapguide-users] What is %24CurrentSelection???
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Mar 17 06:22:17 EDT 2009
The %24 is an UrlEncoded $ sign, so you just get ID=$CurrenctSelection.
$CurrentSelection is likely a PHP variable that is supposed to hold the
current selection (xml).
For some reason you get the variable name and not the variable contents.
Regards, Kenneth Skovhede, GEOGRAF A/S
achectl skrev:
> I would like to delineate how I do the invokeURL command as below:
> My system:
> MapGuide 2009
> PHP bundle option
> Window XP Pro
> MapGuide Studio 2009
> http://n2.nabble.com/file/n2490302/1.jpg
> 1.	I use Sheboygan demo data
> 2.	create the invokeurl commands of flexible web layout
> 3.	URL to invoke is http://127.0.0.1/date.php
> 4.	Key is the ID; Value is $CurrentSelection
> 5.	Layer is the Buildings (SDF)
> http://n2.nabble.com/file/n2490302/2.jpg
> 1.	Building selected
> 2.	InvokeURL command highlighted
> http://n2.nabble.com/file/n2490302/3.jpg
> 1.	New window prompted
> 2.	The url is http://127.0.0.1/date.php?ID=%24CurrentSelection
> My question is why the ID value is %24CurrentSelection, it is not the ID of
> the building layer attribute?
> Or I have do wrong setting?
> Notes: I have amended a little of invokeURL.js. I coped it as below:
>  * Fusion.Widget.InvokeURL
>  * $Id: $
>  * Copyright (c) 2007, DM Solutions Group Inc.
>  * Permission is hereby granted, free of charge, to any person obtaining a
>  * copy of this software and associated documentation files (the
> "Software"),
>  * to deal in the Software without restriction, including without limitation
>  * the rights to use, copy, modify, merge, publish, distribute, sublicense,
>  * and/or sell copies of the Software, and to permit persons to whom the
>  * Software is furnished to do so, subject to the following conditions:
>  * The above copyright notice and this permission notice shall be included
>  * in all copies or substantial portions of the Software.
>  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
> OR
>  * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
>  * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
>  * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
> OTHER
>  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
>  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
>  * DEALINGS IN THE SOFTWARE.
>  * Class: Fusion.Widget.InvokeURL
>  * A widget that will open the configured URL in the target element.
>  * If the Target property points to TaskPane widget, the task will be listed
> in
>  * the menu list of the TaskPane and loaded there.
>  * Otherwise if the target is an existing HTML elementt in the page it will
> be
>  * loaded there, otherwise it will open a new window with that name.
> Fusion.Widget.InvokeURL = Class.create();
> Fusion.Widget.InvokeURL.prototype = {
>     sFeatures : 'menubar=yes,location=no,resizable=yes,status=yes',
>     initialize : function(widgetTag) {
>         //console.log('InvokeURL.initialize');
>         Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag,
> false]);
>         Object.inheritFrom(this, Fusion.Tool.ButtonBase.prototype, []);
>         var json = widgetTag.extension;
>         this.sTarget = json.Target ? json.Target[0] : "InvokeUrlWindow";
>         this.sBaseUrl = json.Url[0];  //must be supplied
>         this.bSelectionOnly = (json.DisableIfSelectionEmpty &&
>                            (json.DisableIfSelectionEmpty[0] == 'true' ||
>                             json.DisableIfSelectionEmpty[0] == '1')) ? true
> : false;
>         this.additionalParameters = [];
>         if (json.AdditionalParameter) {
>             for (var i=0; i<json.AdditionalParameter.length; i++) {
>                 var p = json.AdditionalParameter[i];
>                 var k = p.Key[0];
>                 var v = p.Value[0];
>                 this.additionalParameters.push(k+'='+encodeURIComponent(v));
>         this.enable = Fusion.Widget.InvokeURL.prototype.enable;
>         this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
> this.enable.bind(this));
>         this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
>         this.disable();
>     enable: function() {
>         var map = this.getMap();
>         if (this.bSelectionOnly || !map) {
>             if (map && map.hasSelection()) {
>                 if (this.action) {
>                     this.action.setEnabled(true);
>                 } else {
>                     Fusion.Tool.ButtonBase.prototype.enable.apply(this,[]);
>             } else {
>                 if (this.action) {
>                     this.action.setEnabled(false);
>                 } else {
>                     this.disable();
>         } else {
>             if (this.action) {
>             } else {
>     execute : function() {
>         var url = this.sBaseUrl;
>         //add in other parameters to the url here
>         var params = [];
>         //params.push('LOCALE='+Fusion.locale);
>         //params.push('SESSION='+map.getSessionID());
>         //params.push('MAPNAME='+map.getMapName());
>         params = params.concat(this.additionalParameters);
>         if (url.indexOf('?') < 0) {
>             url += '?';
>         } else if (url.slice(-1) != '&') {
>             url += '&';
>         url += params.join('&');
>         var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
>         if ( taskPaneTarget ) {
>             taskPaneTarget.setContent(url);
>         } else {
>             var pageElement = $(this.sTarget);
>             if ( pageElement ) {
>                 pageElement.src = url;
>             } else {
>                 window.open(url, this.sTarget, this.sFeatures);
