[mapguide-users] What is %24CurrentSelection???
achectl
achectl at gmail.com
Tue Mar 17 05:16:02 EDT 2009
I would like to delineate how I do the invokeURL command as below:
My system:
MapGuide 2009
PHP bundle option
Window XP Pro
MapGuide Studio 2009
http://n2.nabble.com/file/n2490302/1.jpg
1. I use Sheboygan demo data
2. create the invokeurl commands of flexible web layout
3. URL to invoke is http://127.0.0.1/date.php
4. Key is the ID; Value is $CurrentSelection
5. Layer is the Buildings (SDF)
http://n2.nabble.com/file/n2490302/2.jpg
1. Building selected
2. InvokeURL command highlighted
http://n2.nabble.com/file/n2490302/3.jpg
1. New window prompted
2. The url is http://127.0.0.1/date.php?ID=%24CurrentSelection
My question is why the ID value is %24CurrentSelection, it is not the ID of
the building layer attribute?
Or I have do wrong setting?
Notes: I have amended a little of invokeURL.js. I coped it as below:
* Fusion.Widget.InvokeURL
* $Id: $
* Copyright (c) 2007, DM Solutions Group Inc.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the
"Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* Class: Fusion.Widget.InvokeURL
* A widget that will open the configured URL in the target element.
* If the Target property points to TaskPane widget, the task will be listed
in
* the menu list of the TaskPane and loaded there.
* Otherwise if the target is an existing HTML elementt in the page it will
be
* loaded there, otherwise it will open a new window with that name.
Fusion.Widget.InvokeURL = Class.create();
Fusion.Widget.InvokeURL.prototype = {
sFeatures : 'menubar=yes,location=no,resizable=yes,status=yes',
initialize : function(widgetTag) {
//console.log('InvokeURL.initialize');
Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag,
false]);
Object.inheritFrom(this, Fusion.Tool.ButtonBase.prototype, []);
var json = widgetTag.extension;
this.sTarget = json.Target ? json.Target[0] : "InvokeUrlWindow";
this.sBaseUrl = json.Url[0]; //must be supplied
this.bSelectionOnly = (json.DisableIfSelectionEmpty &&
(json.DisableIfSelectionEmpty[0] == 'true' ||
json.DisableIfSelectionEmpty[0] == '1')) ? true
: false;
this.additionalParameters = [];
if (json.AdditionalParameter) {
for (var i=0; i<json.AdditionalParameter.length; i++) {
var p = json.AdditionalParameter[i];
var k = p.Key[0];
var v = p.Value[0];
this.additionalParameters.push(k+'='+encodeURIComponent(v));
this.enable = Fusion.Widget.InvokeURL.prototype.enable;
this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
this.enable.bind(this));
this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
this.disable();
enable: function() {
var map = this.getMap();
if (this.bSelectionOnly || !map) {
if (map && map.hasSelection()) {
if (this.action) {
this.action.setEnabled(true);
} else {
Fusion.Tool.ButtonBase.prototype.enable.apply(this,[]);
} else {
if (this.action) {
this.action.setEnabled(false);
} else {
this.disable();
} else {
if (this.action) {
} else {
execute : function() {
var url = this.sBaseUrl;
//add in other parameters to the url here
var params = [];
//params.push('LOCALE='+Fusion.locale);
//params.push('SESSION='+map.getSessionID());
//params.push('MAPNAME='+map.getMapName());
params = params.concat(this.additionalParameters);
if (url.indexOf('?') < 0) {
url += '?';
} else if (url.slice(-1) != '&') {
url += '&';
url += params.join('&');
var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
if ( taskPaneTarget ) {
taskPaneTarget.setContent(url);
} else {
var pageElement = $(this.sTarget);
if ( pageElement ) {
pageElement.src = url;
} else {
window.open(url, this.sTarget, this.sFeatures);
View this message in context: http://n2.nabble.com/What-is--24CurrentSelection----tp2490302p2490302.html
