[mapguide-users] invokeurl
padmini godavarthi godavarthi.padmini at gmail.com
Wed Mar 18 00:27:57 EDT 2009
iam using Mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
iam using mapguide maestro for creating packages.
Now i want to use Invoke URL (i thought while clicking on feature of the
layer a new window will   be open)
It can be down with invoke url? and how to use it?
Can u guide me plz
Regards,
Padmini.
GordonL wrote:
> I would try the INVOKEURL with the Basic Web Layout and see if the issue
> is with:
> PHP in Apache
> PHP in IIS (if you are using IIS)
> FUSION
> MAPGUIDE.
> That way you will know why the $CurrentSelection is not passing you the
> XML.
> gordon
> achectl wrote:
>> Hi Gordon,
>> I'm looking for invokeurl help!
>> I tried it for many time; the result is same! All the parameter value is
>> %24CurrectSelection. Why?
>> Do I need to modify the invokeurl.js? I did amended it -
>> http://trac.osgeo.org/mapguide/ticket/832.
>> I created the command by using MapGuide studio. The invokeurl.js should
>> be involved.
>> Appreciate if you reply.
>> Thanks
>> GordonL wrote:
>>> Hi Andrew,
>>> ok I figured it out.  It is the InvokeURL.js file.
>>> This file is found in the following folder:
>>> \www\fusion\widgets
>>> Here is the issue:
>>> At line 40 it shows:
>>> Fusion.Widget.InvokeURL.prototype = {
>>>     sFeatures :
>>> 'menubar=no,location=no,resizable=yes,status=no,scrollbars=yes',
>>> Which is fine.  I changed resizable=yes and added scrollbars=yes...so
>>> far so good...
>>> But, at line 120, it reads:
>>>                 window.open(url, this.sTarget, this.sWinFeatures);
>>> Ok, so the issue is that there is NO sWinFeatures...
>>> I changed it to read:
>>>                 window.open(url, this.sTarget, this.sFeatures);
>>> And voilà!  I am in business...whew. I thought I was losing my touch.
>>> gordon
>>> Andrew DeMerchant wrote:
>>>> It wasn't part of the widget - i've been away from Fusion for too long
>>>> now, and really can't recall. I would imagine it was in the .js file
>>>> for
>>>> that widget...sorry I'm no more help than that!
>>>> On 1/29/2009 11:44 AM, GordonL wrote:
>>>>> Hi Andrew,
>>>>> I am having trouble finding the entry in Nabble.  Do you have an
>>>>> example?  I
>>>>> am sure I did this a couple of years ago, but I can't find it.  Can it
>>>>> be
>>>>> part of the Widget XML in Studio too?
>>>>> thanks
>>>>> gordon
>>>>>> I did...I also turned on the scrollbars - but I can't recall how at
>>>>>> the
>>>>>> moment....do a search on Nabble, and you should find the answer.
>>>>>> Andrew
>>>>>> GordonL wrote:
>>>>>>> Did you figure this out with Flexible Web Layouts?  This fix works
>>>>>>> great
>>>>>>> for
>>>>>>> Simple Web Layouts but how do we turn on Scrolling/Toolbars in the
>>>>>>> InvokeURL
>>>>>>> for Fusion?
>>>>>>> Is it part of the InvokeURL.js file in the /fusion/wigets/ folder?
>>>>>>> thanks
>>>>>>> gordon
>>>>>>>> Is there a way to modify the InvokeURL command to have it open a
>>>>>>>> window
>>>>>>>> with scrollbars and toolbars? Right now, if you tell it to open in
>>>>>>>> a new
>>>>>>>> window, that window never has scrollbars or toolbars. I need to
>>>>>>>> turn
>>>>>>>> those on somehow. I've looked through the AJAX viewer php files,
>>>>>>>> but
>>>>>>>> can't find the spot that I'd change.
>>>>>>>> Andrew
>>>>>>>> 	*Andrew DeMerchant*
>>>>>>>> *Computer Technologist*
>>>>>>>> ph.1-877-2GEMTEC x.163
>>>>>>>> fax 506-453-9470
>>>>>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>>>>>> /191 Doak Road
>>>>>>>> Fredericton, NB, Canada
>>>>>>>> E3C 2E6
>>>>>>>> _______________________________________________
>>>>>>>> mapguide-users mailing list
>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> 	*Andrew DeMerchant*
>>>> fax 506-453-9470
>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> E3C 2E6
View this message in context: http://n2.nabble.com/invokeurl-tp1816596p2495356.html
