[mapguide-users] postgisconnection
    Arnaud De Groof
    Arnaud.DeGroof at spacebel.be
    Tue Mar 17 07:56:26 EDT 2009
I tried to connect Mapguide OS 2.0.2 with a PostGreSQL 8.2 + PostGis
database via FDO OGR Provider 3.3.0.
I copied the three dll files (PostGISProvider.dll, PostGISOverrides.dll,
PostGISMessage.dll) from OSGeo Website into the
MapGuideOpenSource2.0\Server\Bin\FDO folder and I updated the
providers.xml file.
In MapGuide Maestro, I created a dataconnection with the OSGeo FDO
Provider for PostGIS. Unfortunately, when I tested the connection with
the specific parameters (database, server, port,..), the following error
is encountered:
Error: An exception occurred in FDO component.
        Unable to load the FDO Provider: (null)
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute line 100 file
\feature\OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open line 262 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\m
anager\FdoConnectionManager.cpp   An exception occurred in FDO
component.
Thanks
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090317/30ac6992/attachment.html
