[mapguide-users] postgisconnection
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Mar 17 09:57:59 EDT 2009
Try using "Dependency Walker" on the OGRProvider.dll or
PostGISProvider.dll (depending on which you use).
http://www.dependencywalker.com/
I think you need the pglib file from PostGIS.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> Hi,
> I tried to connect Mapguide OS 2.0.2 with a PostGreSQL 8.2 + PostGis
> database via FDO OGR Provider 3.3.0.
> I copied the three dll files (/PostGISProvider.dll/,
> /PostGISOverrides.dll/, /PostGISMessage.dll/) from OSGeo Website into
> the /MapGuideOpenSource2.0\Server\Bin\FDO/ folder and I updated the
> /providers.xml/ file.
> In MapGuide Maestro, I created a dataconnection with the OSGeo FDO
> Provider for PostGIS. Unfortunately, when I tested the connection with
> the specific parameters (database, server, port,..), the following
> error is encountered:
> /Error: An exception occurred in FDO component./
> / Unable to load the FDO Provider: (null) /
> / StackTrace:/
> / - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp/
> / - MgOpTestFeatureSourceConnection.Execute line 100 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp/
> / - MgFdoConnectionManager.Open line 262 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> /Unable to load the FDO Provider: (null)/
> Thanks
> Arnaud De Groof
> E-MAIL DISCLAIMER*
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy
> this E-mail. Disclosure, reproduction or distribution of this document
> and its possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of
> the current information given that unencrypted electronic transmission
> cannot currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the
> information contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090317/e3b3e518/attachment.html
