[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Mar 17 10:45:10 EDT 2009
I'm am a bit puzzled by this:
String xmlString = doc.DocumentElement.OuterXml;
"After modif = \ n "+"<? xml version ='1 .0 'encoding =' UTF-8'?>"+ xmlString
It seems that the xmlString is missing the xml preamble?
Just to clarify: the document MUST have the utf-8 xml preamble, and MUST
NOT have the utf-8 BOM.
The file you sent does not appear to be made from the encoded data.
You must do something like:
using(System.IO.FileStream fs = System.IO.File.Create("test.xml"))
  fs.Write(encodedDefinition, 0, encodedDefinition.Length);
Otherwise there are too many places that can introduce small differences.
btw, in C#, you can make a string with quotes like this:
"xmlns=\"namespace\""
or
@"xmlns=""namespace""" //VB style
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> The file is generate in my code after the instruction
> 'resourceSrvc.SetResource(webLayoutId, contentByteSource.GetReader(),
> null);' So, i do not understand why the file is fine and my mapdefinition in
> my layout generate the error An exception occurred in the XML parser.
> If you have few minutes you can see the trace of my function ag_SetLayoutMap
> here :  http://patxi.mayol.free.fr/Trace.htm
> and a sample of my C# code here :  http://patxi.mayol.free.fr/sample.asp
> http://patxi.mayol.free.fr/sample.asp , who is describe the ag_SetLayoutMap
> function.
> thanks
> regards, Francis
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Is this a question?
>> The un-edited file loads fine for me.
>> euskalmap skrev:
>>> Hi,
>>> I have not send the good link of my file; in the previous version , i
>>> have
>>> trying to delete in the xml the string
>>> "xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd".
>>> So, my file is :  http://patxi.mayol.free.fr/Untitled1.xml
>>> So i test GetResourceContent rather than SetResource :
>>> If i try  http://localhost/mapguide/mapagent/index.html
>>> http://localhost/mapguide/mapagent/index.html  with GetResourceContent on
>>> "Library://Ag Base/Mpg Urbanisme.WebLayout" and submit, i have this
>>> result :
>>> http://n2.nabble.com/file/n2490672/test.jpg
>>> The message in header, in french, is in english : This file XML does not
>>> seem to have of information of style associated with him. The tree of the
>>> document is shown below.
>>> SO
>>>> A bit tricky, something to do with how .Net handles Xml I think.
>>>> The document is missing the attribute:
>>>> Which is required, because it is used for versioning and validation.
>>>> If you take your document and open this page:
>>>> Then click "Resource" -> "SetResource", point out the file,
>>>> and in the "ResourceID" field type: "Library://mytest.WebLayout".
>>>> Then set the "Content" field to point to the file and click submit.
>>>> You will see the error you mention.
>>>> Now add the above attribute, so the second line in the document becomes:
>>>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>>>> Save the document, click back in the browser, and then "Submit" once
>>>> more.
>>>> This time it works. (Remember to check that the ResourceID and Content
>>>> field has not been reset).
>>>> euskalmap skrev:
>>>>> Hi,
>>>>> Yes, i have see the log file, but there is no more information that
>>>>> 'XML
>>>>> Parser error'.
>>>>> The logfile is :
>>>>> http://n2.nabble.com/file/n2474100/logfile.jpg
>>>>> About the XML file, after modification i have this file :
>>>>> http://patxi.mayol.free.fr/mytest.xml
>>>>> Thanks
>>>>> regards
>>>>>> Did you look in the error.log file?
>>>>>> Could you try to save the xml document after modification, and send a
>>>>>> link to it?
>>>>>> euskalmap skrev:
>>>>>>> Hi,
>>>>>>> In fact, before modification, i have
>>>>>>> MgResourceIdentifier webLayoutId = new
>>>>>>> MgResourceIdentifier(pst_weblayout)
>>>>>>> with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
>>>>>>> I search the xml node for modify Mapdefinition resource and
>>>>>>> after modification i have in instruction
>>>>>>> webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
>>>>>>> with str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
>>>>>>> So, i set the resource and i have the message 'An exception occurred
>>>>>>> in
>>>>>>> the
>>>>>>> XML parser.'
>>>>>>> I say it is simply to migrate vb to c#, but before i want to
>>>>>>> understand.
>>>>>>> I have use same sample who use this method on the forum; but i do not
>>>>>>> explain where is my bug?
>>>>>>> thanks a lot for your help
>>>>>>>> It is very trivial to convert the sample to C#... in fact I just
>>>>>>>> did:
>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
>>>>>>>> If you just want to understand what happens, there should be a more
>>>>>>>> verbose message in the error.log:
>>>>>>>> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
>>>>>>>> Also, are you certain that the pst_map is a valid map identifier,
>>>>>>>> and
>>>>>>>> that str_NewMapDefinition is a valid resource identifier?
>>>>>>>> I'm guessing that pst_map is a string like:
>>>>>>>> "Library://map.MapDefinition", so your str_NewMapDefinition becomes:
>>>>>>>> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
>>>>>>>> euskalmap skrev:
>>>>>>>>> Hi,
>>>>>>>>> It do not run with the parameter false in the instruction
>>>>>>>>> UTF8Encoding
>>>>>>>>> utf8
>>>>>>>>> = new UTF8Encoding(false);
>>>>>>>>> In your link sample(
>>>>>>>>> ), it is a vb code with the mapguide maetro api; i will not change
>>>>>>>>> all
>>>>>>>>> my
>>>>>>>>> code because i use c# with mapguide api; i want to undestand why it
>>>>>>>>> do
>>>>>>>>> not
>>>>>>>>> run; i use the same method to change the filter in layers and it
>>>>>>>>> run
>>>>>>>>> very
>>>>>>>>> well ! what's append in my code?
>>>>>>>>> thanks
>>>>>>>>>> You need to create the UTF8Encoding object with the parameter
>>>>>>>>>> "false"
>>>>>>>>>> (meaning disable BOM).
>>>>>>>>>> A slightly easier way to do this:
>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>> Hi
>>>>>>>>>>> I provide the end user with a link to my special page (see the
>>>>>>>>>>> code1).
>>>>>>>>>>> In
>>>>>>>>>>> that page i redirect to the MapGuide viewer files
>>>>>>>>>>> (Response.Redirect).
>>>>>>>>>>> code1:
>>>>>>>>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>>>>>>>>> The fonction SetLayout Map modify the mapdefinition in my layout.
>>>>>>>>>>> See
>>>>>>>>>>> image
>>>>>>>>>>> here :
>>>>>>>>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>>>>>>>>> The problem : the layout is not modify and i have this message :
>>>>>>>>>>> An
>>>>>>>>>>> Have you an idea ?
>>>>>>>>>>> Thanks
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090317/98ec69b2/attachment.html
