[mapguide-users] Date column problem
Haris Kurtagic
haris at sl-king.com
Wed Mar 18 10:02:52 EDT 2009
If you are using King.Oracle provider, there was bug with reading date
columns.
There is new version of provider 0.8.6 with fix for it.
www.sl-king.com/fdooracle
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
Sent: Thursday, March 12, 2009 12:32 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Date column problem
I have created a search functionality for my system.
It selects objects based on user input, zoom to the selected object and
highlights it on the map.
This work fine. I however, have a problem with one of my searches as the
spatial table the layer is created from contains a date field.
Now when I do the search, the zoom works fine, but on the selection I
get
the following:
OSGeo.MapGuide.MgDateTimeException: A date and/or time exception
occurred.
I use oracle 10g database.
I cannot remove the date column from the table as it is a requirement
from
the client that there should be a date.
Does anybody have any suggestions?
View this message in context:
http://n2.nabble.com/Date-column-problem-tp2466769p2466769.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
