[mapguide-users] Date column problem
marius.360 marius at osssa.co.za
Wed Mar 18 10:07:47 EDT 2009
Thanks,
I am using King.Oracle provider version 0.8.5. I will switch to 0.8.6
immediatly.
Thanks for the reply,
Marius
Haris Kurtagic wrote:
> If you are using King.Oracle provider, there was bug with reading date
> columns.
> There is new version of provider 0.8.6 with fix for it.
> www.sl-king.com/fdooracle
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
> Sent: Thursday, March 12, 2009 12:32 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Date column problem
> I have created a search functionality for my system.
> It selects objects based on user input, zoom to the selected object and
> highlights it on the map.
> This work fine. I however, have a problem with one of my searches as the
> spatial table the layer is created from contains a date field.
> Now when I do the search, the zoom works fine, but on the selection I
> get
> the following:
> OSGeo.MapGuide.MgDateTimeException: A date and/or time exception
> occurred.
> I use oracle 10g database.
> I cannot remove the date column from the table as it is a requirement
> from
> the client that there should be a date.
> Does anybody have any suggestions?
> http://n2.nabble.com/Date-column-problem-tp2466769p2466769.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Date-column-problem-tp2466769p2497354.html
