[mapguide-users] SQL datastore and Point Features
Zac Spitzer zac.spitzer at gmail.com
Wed Mar 18 20:47:35 EDT 2009
which database are you using?
On Thu, Mar 19, 2009 at 11:43 AM, Jamo <adam.jamison at portbris.com.au> wrote:
> If anyone is curious I found the porblem!!!!
> I had Lat/Long stored in the DB with no Z value so I only picked Lat/Long as
> the X/Y Values, It would seem Mapguide requires a Z value in order to
> process correctly... I have applied a Z value and now I can select these
> features....
> Perhaps this is a bug and if no Z value is described a default value of 0
> should be used....
> Very frustrating stuff
> Jamo wrote:
>> I am trying to display point features that are stored in Lat/Long in a sql
>> database in my current map being GDA94 / Zone 56, This data is reprojected
>> in the correct position (a single point is all that is available at the
>> moment for testing so 1 point displays in the correct position) and
>> displayed in the correct position.
>> The problem I'm encountering is when I try to select the point feature ...
>> it does not seem to be selectable... however If I create a map in it's
>> native coordinate system I can then select the feature..... Is this a bug?
> View this message in context: http://n2.nabble.com/SQL-datastore-and-Point-Features-tp2494796p2500486.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
