[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Mar 19 13:11:11 EDT 2009
It looks like it is bad, I try not to deal with xml as text strings.
You can do this instead:
System.IO.MemoryStream ms = new System.IO.MemoryStream();
doc.Save(ms);
byte[] encodedBytes = ms.ToArray();
No encoding stuff needed, and you get the document as it would look when
written to a file.
Unfortunately this seems to add the BOM, which breaks MapGuide.
In the MaestroAPI, I use this class:
http://svn.osgeo.org/mapguide/trunk/Tools/Maestro/MaestroAPI/Utf8XmlWriter.cs
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> When i load the xml with this instruction :
>     XmlDocument doc = new XmlDocument();
>    String xmlLayoutDef = byteReader.ToString();
> there is the preamble <?xml version="1.0" encoding="utf-8"?>
> Later, the instruction
>     String xmlString = doc.DocumentElement.OuterXml;
> remove the preamble.
> Other information : if i load the file
> http://patxi.mayol.free.fr/Untitled1.xml
> http://patxi.mayol.free.fr/Untitled1.xml  in an editor XML like altova, for
> example, i have this message when i want to save it : This file is not
> valid: Unable to load schema with target namespace " from
> 'WebLayout-1.0.0.xsd''.
> So, is this instruction String xmlString = doc.DocumentElement.OuterXml; bad
> ? I have find in sample on the forum?
> What you think about it?.
> Thanks
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Ok, that file does not have the preamble (the "<?xml version=\"1.0\"
>> encoding=\"utf-8\"?>" string).
>> Not sure if it fixes your problem if you add it, but its worth a try.
>> The line mentioned seems to only check that the first element
>> (WebLayout) matches the xsd file (WebLayout).
>> I wrote about the doublequote, because there was a line with:
>> char doublequote = (char)34;
>> which works, but is not very intuitive and suggests that someone did not
>> know how to escape doublequotes.
>> euskalmap skrev:
>>> I have do
>>>   using(System.IO.FileStream fs = System.IO.File.Create("test.xml"))
>>>   fs.Write(encodedDefinition, 0, encodedDefinition.Length);
>>> The result is here :  http://patxi.mayol.free.fr/test.xml
>>> How know that my document have the utf-8 xml preamble ?
>>> About the string "xmlns=\"namespace\"", i have not this in my xml file.
>>> Thanks
>>>> I'm am a bit puzzled by this:
>>>> "After modif = \ n "+"<? xml version ='1 .0 'encoding =' UTF-8'?>"+
>>>> xmlString
>>>> It seems that the xmlString is missing the xml preamble?
>>>> Just to clarify: the document MUST have the utf-8 xml preamble, and MUST
>>>> NOT have the utf-8 BOM.
>>>> The file you sent does not appear to be made from the encoded data.
>>>> You must do something like:
>>>> Otherwise there are too many places that can introduce small
>>>> differences.
>>>> btw, in C#, you can make a string with quotes like this:
>>>> or
>>>> @"xmlns=""namespace""" //VB style
>>>> euskalmap skrev:
>>>>> The file is generate in my code after the instruction
>>>>> 'resourceSrvc.SetResource(webLayoutId, contentByteSource.GetReader(),
>>>>> null);' So, i do not understand why the file is fine and my
>>>>> mapdefinition
>>>>> in
>>>>> my layout generate the error An exception occurred in the XML parser.
>>>>> If you have few minutes you can see the trace of my function
>>>>> ag_SetLayoutMap
>>>>> here :  http://patxi.mayol.free.fr/Trace.htm
>>>>> and a sample of my C# code here :
>>>>> http://patxi.mayol.free.fr/sample.asp
>>>>> http://patxi.mayol.free.fr/sample.asp , who is describe the
>>>>> ag_SetLayoutMap
>>>>> function.
>>>>> thanks
>>>>> regards, Francis
>>>>>> Is this a question?
>>>>>> The un-edited file loads fine for me.
>>>>>> euskalmap skrev:
>>>>>>> Hi,
>>>>>>> I have not send the good link of my file; in the previous version , i
>>>>>>> have
>>>>>>> trying to delete in the xml the string
>>>>>>> "xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd".
>>>>>>> So, my file is :  http://patxi.mayol.free.fr/Untitled1.xml
>>>>>>> So i test GetResourceContent rather than SetResource :
>>>>>>> If i try  http://localhost/mapguide/mapagent/index.html
>>>>>>> http://localhost/mapguide/mapagent/index.html  with
>>>>>>> GetResourceContent
>>>>>>> on
>>>>>>> "Library://Ag Base/Mpg Urbanisme.WebLayout" and submit, i have this
>>>>>>> result :
>>>>>>> http://n2.nabble.com/file/n2490672/test.jpg
>>>>>>> The message in header, in french, is in english : This file XML does
>>>>>>> not
>>>>>>> seem to have of information of style associated with him. The tree of
>>>>>>> the
>>>>>>> document is shown below.
>>>>>>> SO
>>>>>>>> A bit tricky, something to do with how .Net handles Xml I think.
>>>>>>>> The document is missing the attribute:
>>>>>>>> Which is required, because it is used for versioning and validation.
>>>>>>>> If you take your document and open this page:
>>>>>>>> Then click "Resource" -> "SetResource", point out the file,
>>>>>>>> and in the "ResourceID" field type: "Library://mytest.WebLayout".
>>>>>>>> Then set the "Content" field to point to the file and click submit.
>>>>>>>> You will see the error you mention.
>>>>>>>> Now add the above attribute, so the second line in the document
>>>>>>>> becomes:
>>>>>>>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>>>>>>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>>>>>>>> Save the document, click back in the browser, and then "Submit" once
>>>>>>>> more.
>>>>>>>> This time it works. (Remember to check that the ResourceID and
>>>>>>>> Content
>>>>>>>> field has not been reset).
>>>>>>>> euskalmap skrev:
>>>>>>>>> Hi,
>>>>>>>>> Yes, i have see the log file, but there is no more information that
>>>>>>>>> 'XML
>>>>>>>>> Parser error'.
>>>>>>>>> The logfile is :
>>>>>>>>> http://n2.nabble.com/file/n2474100/logfile.jpg
>>>>>>>>> About the XML file, after modification i have this file :
>>>>>>>>> http://patxi.mayol.free.fr/mytest.xml
>>>>>>>>> Thanks
>>>>>>>>> regards
>>>>>>>>>> Did you look in the error.log file?
>>>>>>>>>> Could you try to save the xml document after modification, and
>>>>>>>>>> send
>>>>>>>>>> a
>>>>>>>>>> link to it?
>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>> Hi,
>>>>>>>>>>> In fact, before modification, i have
>>>>>>>>>>> MgResourceIdentifier webLayoutId = new
>>>>>>>>>>> MgResourceIdentifier(pst_weblayout)
>>>>>>>>>>> with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
>>>>>>>>>>> I search the xml node for modify Mapdefinition resource and
>>>>>>>>>>> after modification i have in instruction
>>>>>>>>>>> webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
>>>>>>>>>>> with str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
>>>>>>>>>>> So, i set the resource and i have the message 'An exception
>>>>>>>>>>> occurred
>>>>>>>>>>> in
>>>>>>>>>>> the
>>>>>>>>>>> XML parser.'
>>>>>>>>>>> I say it is simply to migrate vb to c#, but before i want to
>>>>>>>>>>> understand.
>>>>>>>>>>> I have use same sample who use this method on the forum; but i do
>>>>>>>>>>> not
>>>>>>>>>>> explain where is my bug?
>>>>>>>>>>> thanks a lot for your help
>>>>>>>>>>>> It is very trivial to convert the sample to C#... in fact I just
>>>>>>>>>>>> did:
>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
>>>>>>>>>>>> If you just want to understand what happens, there should be a
>>>>>>>>>>>> more
>>>>>>>>>>>> verbose message in the error.log:
>>>>>>>>>>>> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
>>>>>>>>>>>> Also, are you certain that the pst_map is a valid map
>>>>>>>>>>>> identifier,
>>>>>>>>>>>> and
>>>>>>>>>>>> that str_NewMapDefinition is a valid resource identifier?
>>>>>>>>>>>> I'm guessing that pst_map is a string like:
>>>>>>>>>>>> "Library://map.MapDefinition", so your str_NewMapDefinition
>>>>>>>>>>>> becomes:
>>>>>>>>>>>> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
>>>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> It do not run with the parameter false in the instruction
>>>>>>>>>>>>> UTF8Encoding
>>>>>>>>>>>>> utf8
>>>>>>>>>>>>> = new UTF8Encoding(false);
>>>>>>>>>>>>> In your link sample(
>>>>>>>>>>>>> ), it is a vb code with the mapguide maetro api; i will not
>>>>>>>>>>>>> change
>>>>>>>>>>>>> all
>>>>>>>>>>>>> my
>>>>>>>>>>>>> code because i use c# with mapguide api; i want to undestand
>>>>>>>>>>>>> why
>>>>>>>>>>>>> it
>>>>>>>>>>>>> do
>>>>>>>>>>>>> not
>>>>>>>>>>>>> run; i use the same method to change the filter in layers and
>>>>>>>>>>>>> it
>>>>>>>>>>>>> run
>>>>>>>>>>>>> very
>>>>>>>>>>>>> well ! what's append in my code?
>>>>>>>>>>>>> thanks
>>>>>>>>>>>>>> You need to create the UTF8Encoding object with the parameter
>>>>>>>>>>>>>> "false"
>>>>>>>>>>>>>> (meaning disable BOM).
>>>>>>>>>>>>>> A slightly easier way to do this:
>>>>>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>>>>>> Hi
>>>>>>>>>>>>>>> I provide the end user with a link to my special page (see
>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>> code1).
>>>>>>>>>>>>>>> In
>>>>>>>>>>>>>>> that page i redirect to the MapGuide viewer files
>>>>>>>>>>>>>>> (Response.Redirect).
>>>>>>>>>>>>>>> code1:
>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>>>>>>>>>>>>> The fonction SetLayout Map modify the mapdefinition in my
>>>>>>>>>>>>>>> layout.
>>>>>>>>>>>>>>> See
>>>>>>>>>>>>>>> image
>>>>>>>>>>>>>>> here :
>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>>>>>>>>>>>>> The problem : the layout is not modify and i have this
>>>>>>>>>>>>>>> message
>>>>>>>>>>>>>>> An
>>>>>>>>>>>>>>> Have you an idea ?
>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090319/54514faf/attachment.html
