[mapguide-users] Modify mapdefinition in a layout
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Mar 20 04:39:46 EDT 2009
If that file is missing, you should not be able to save any weblayout,
no matter what, so I think it is correctly avalible.
Regards, Kenneth Skovhede, GEOGRAF A/S
euskalmap skrev:
> Hi,
> It seems that MapguideServer do not acceded at directory C:/Program
> Files/MapGuideOpenSource2.0/Server/Schema/; so, it do not find the file
> WebLayouy-1.0.0.xsd schema?
> What you think about it?
> euskalmap wrote:
>> ERROR:
>> The instruction
>> String xmlString = doc.DocumentElement.OuterXml;
>> DO NOT remove the preamble. But i thought that OuterXml remove the first
>> tag.
>> Sorry for my error
>> euskalmap wrote:
>>> When i load the xml with this instruction :
>>> XmlDocument doc = new XmlDocument();
>>> String xmlLayoutDef = byteReader.ToString();
>>> there is the preamble <?xml version="1.0" encoding="utf-8"?>
>>> Later, the instruction
>>> Other information : if i load the file
>>> http://patxi.mayol.free.fr/Untitled1.xml
>>> http://patxi.mayol.free.fr/Untitled1.xml in an editor XML like altova,
>>> for example, i have this message when i want to save it : This file is
>>> not valid: Unable to load schema with target namespace " from
>>> 'WebLayout-1.0.0.xsd''.
>>> So, is this instruction String xmlString = doc.DocumentElement.OuterXml;
>>> bad ? I have find in sample on the forum?
>>> What you think about it?.
>>> Thanks
>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>> Ok, that file does not have the preamble (the "<?xml version=\"1.0\"
>>>> encoding=\"utf-8\"?>" string).
>>>> Not sure if it fixes your problem if you add it, but its worth a try.
>>>> The line mentioned seems to only check that the first element
>>>> (WebLayout) matches the xsd file (WebLayout).
>>>> I wrote about the doublequote, because there was a line with:
>>>> char doublequote = (char)34;
>>>> which works, but is not very intuitive and suggests that someone did not
>>>> know how to escape doublequotes.
>>>> euskalmap skrev:
>>>>> I have do
>>>>> using(System.IO.FileStream fs = System.IO.File.Create("test.xml"))
>>>>> fs.Write(encodedDefinition, 0, encodedDefinition.Length);
>>>>> The result is here : http://patxi.mayol.free.fr/test.xml
>>>>> How know that my document have the utf-8 xml preamble ?
>>>>> About the string "xmlns=\"namespace\"", i have not this in my xml file.
>>>>> Thanks
>>>>>> I'm am a bit puzzled by this:
>>>>>> "After modif = \ n "+"<? xml version ='1 .0 'encoding =' UTF-8'?>"+
>>>>>> xmlString
>>>>>> It seems that the xmlString is missing the xml preamble?
>>>>>> Just to clarify: the document MUST have the utf-8 xml preamble, and
>>>>>> MUST
>>>>>> NOT have the utf-8 BOM.
>>>>>> The file you sent does not appear to be made from the encoded data.
>>>>>> You must do something like:
>>>>>> Otherwise there are too many places that can introduce small
>>>>>> differences.
>>>>>> btw, in C#, you can make a string with quotes like this:
>>>>>> or
>>>>>> @"xmlns=""namespace""" //VB style
>>>>>> euskalmap skrev:
>>>>>>> The file is generate in my code after the instruction
>>>>>>> 'resourceSrvc.SetResource(webLayoutId, contentByteSource.GetReader(),
>>>>>>> null);' So, i do not understand why the file is fine and my
>>>>>>> mapdefinition
>>>>>>> in
>>>>>>> my layout generate the error An exception occurred in the XML parser.
>>>>>>> If you have few minutes you can see the trace of my function
>>>>>>> ag_SetLayoutMap
>>>>>>> here : http://patxi.mayol.free.fr/Trace.htm
>>>>>>> and a sample of my C# code here :
>>>>>>> http://patxi.mayol.free.fr/sample.asp
>>>>>>> http://patxi.mayol.free.fr/sample.asp , who is describe the
>>>>>>> ag_SetLayoutMap
>>>>>>> function.
>>>>>>> thanks
>>>>>>> regards, Francis
>>>>>>>> Is this a question?
>>>>>>>> The un-edited file loads fine for me.
>>>>>>>> euskalmap skrev:
>>>>>>>>> Hi,
>>>>>>>>> I have not send the good link of my file; in the previous version ,
>>>>>>>>> i
>>>>>>>>> have
>>>>>>>>> trying to delete in the xml the string
>>>>>>>>> "xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd".
>>>>>>>>> So, my file is : http://patxi.mayol.free.fr/Untitled1.xml
>>>>>>>>> So i test GetResourceContent rather than SetResource :
>>>>>>>>> If i try http://localhost/mapguide/mapagent/index.html
>>>>>>>>> http://localhost/mapguide/mapagent/index.html with
>>>>>>>>> GetResourceContent
>>>>>>>>> on
>>>>>>>>> "Library://Ag Base/Mpg Urbanisme.WebLayout" and submit, i have this
>>>>>>>>> result :
>>>>>>>>> http://n2.nabble.com/file/n2490672/test.jpg
>>>>>>>>> The message in header, in french, is in english : This file XML
>>>>>>>>> does
>>>>>>>>> not
>>>>>>>>> seem to have of information of style associated with him. The tree
>>>>>>>>> of
>>>>>>>>> the
>>>>>>>>> document is shown below.
>>>>>>>>> SO
>>>>>>>>>> A bit tricky, something to do with how .Net handles Xml I think.
>>>>>>>>>> The document is missing the attribute:
>>>>>>>>>> Which is required, because it is used for versioning and
>>>>>>>>>> validation.
>>>>>>>>>> If you take your document and open this page:
>>>>>>>>>> Then click "Resource" -> "SetResource", point out the file,
>>>>>>>>>> and in the "ResourceID" field type: "Library://mytest.WebLayout".
>>>>>>>>>> Then set the "Content" field to point to the file and click
>>>>>>>>>> submit.
>>>>>>>>>> You will see the error you mention.
>>>>>>>>>> Now add the above attribute, so the second line in the document
>>>>>>>>>> becomes:
>>>>>>>>>> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>>>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>>>>>>>>>> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
>>>>>>>>>> Save the document, click back in the browser, and then "Submit"
>>>>>>>>>> once
>>>>>>>>>> more.
>>>>>>>>>> This time it works. (Remember to check that the ResourceID and
>>>>>>>>>> Content
>>>>>>>>>> field has not been reset).
>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>> Hi,
>>>>>>>>>>> Yes, i have see the log file, but there is no more information
>>>>>>>>>>> that
>>>>>>>>>>> 'XML
>>>>>>>>>>> Parser error'.
>>>>>>>>>>> The logfile is :
>>>>>>>>>>> http://n2.nabble.com/file/n2474100/logfile.jpg
>>>>>>>>>>> About the XML file, after modification i have this file :
>>>>>>>>>>> http://patxi.mayol.free.fr/mytest.xml
>>>>>>>>>>> Thanks
>>>>>>>>>>> regards
>>>>>>>>>>>> Did you look in the error.log file?
>>>>>>>>>>>> Could you try to save the xml document after modification, and
>>>>>>>>>>>> send
>>>>>>>>>>>> a
>>>>>>>>>>>> link to it?
>>>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> In fact, before modification, i have
>>>>>>>>>>>>> MgResourceIdentifier webLayoutId = new
>>>>>>>>>>>>> MgResourceIdentifier(pst_weblayout)
>>>>>>>>>>>>> with pst_weblayout = "Library://Ag Base/MyLayout.WebLayout"
>>>>>>>>>>>>> I search the xml node for modify Mapdefinition resource and
>>>>>>>>>>>>> after modification i have in instruction
>>>>>>>>>>>>> webLayoutId = new MgResourceIdentifier(str_NewMapDefinition)
>>>>>>>>>>>>> with
>>>>>>>>>>>>> str_NewMapDefinition=Session:xxxxxxxxx//MyMap.MapDefinition
>>>>>>>>>>>>> So, i set the resource and i have the message 'An exception
>>>>>>>>>>>>> occurred
>>>>>>>>>>>>> in
>>>>>>>>>>>>> the
>>>>>>>>>>>>> XML parser.'
>>>>>>>>>>>>> I say it is simply to migrate vb to c#, but before i want to
>>>>>>>>>>>>> understand.
>>>>>>>>>>>>> I have use same sample who use this method on the forum; but i
>>>>>>>>>>>>> do
>>>>>>>>>>>>> not
>>>>>>>>>>>>> explain where is my bug?
>>>>>>>>>>>>> thanks a lot for your help
>>>>>>>>>>>>>> It is very trivial to convert the sample to C#... in fact I
>>>>>>>>>>>>>> just
>>>>>>>>>>>>>> did:
>>>>>>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
>>>>>>>>>>>>>> If you just want to understand what happens, there should be a
>>>>>>>>>>>>>> more
>>>>>>>>>>>>>> verbose message in the error.log:
>>>>>>>>>>>>>> C:\Program Files\MapGuideOpenSource2.0\Server\logs\error.log
>>>>>>>>>>>>>> Also, are you certain that the pst_map is a valid map
>>>>>>>>>>>>>> identifier,
>>>>>>>>>>>>>> and
>>>>>>>>>>>>>> that str_NewMapDefinition is a valid resource identifier?
>>>>>>>>>>>>>> I'm guessing that pst_map is a string like:
>>>>>>>>>>>>>> "Library://map.MapDefinition", so your str_NewMapDefinition
>>>>>>>>>>>>>> becomes:
>>>>>>>>>>>>>> Session:<sessionid>//Library://map.MapDefinition.MapDefinition
>>>>>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> It do not run with the parameter false in the instruction
>>>>>>>>>>>>>>> UTF8Encoding
>>>>>>>>>>>>>>> utf8
>>>>>>>>>>>>>>> = new UTF8Encoding(false);
>>>>>>>>>>>>>>> In your link sample(
>>>>>>>>>>>>>>> ), it is a vb code with the mapguide maetro api; i will not
>>>>>>>>>>>>>>> change
>>>>>>>>>>>>>>> all
>>>>>>>>>>>>>>> my
>>>>>>>>>>>>>>> code because i use c# with mapguide api; i want to undestand
>>>>>>>>>>>>>>> why
>>>>>>>>>>>>>>> it
>>>>>>>>>>>>>>> do
>>>>>>>>>>>>>>> not
>>>>>>>>>>>>>>> run; i use the same method to change the filter in layers and
>>>>>>>>>>>>>>> it
>>>>>>>>>>>>>>> run
>>>>>>>>>>>>>>> very
>>>>>>>>>>>>>>> well ! what's append in my code?
>>>>>>>>>>>>>>> thanks
>>>>>>>>>>>>>>>> You need to create the UTF8Encoding object with the
>>>>>>>>>>>>>>>> parameter
>>>>>>>>>>>>>>>> "false"
>>>>>>>>>>>>>>>> (meaning disable BOM).
>>>>>>>>>>>>>>>> A slightly easier way to do this:
>>>>>>>>>>>>>>>> euskalmap skrev:
>>>>>>>>>>>>>>>>> Hi
>>>>>>>>>>>>>>>>> I provide the end user with a link to my special page (see
>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>> code1).
>>>>>>>>>>>>>>>>> In
>>>>>>>>>>>>>>>>> that page i redirect to the MapGuide viewer files
>>>>>>>>>>>>>>>>> (Response.Redirect).
>>>>>>>>>>>>>>>>> code1:
>>>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2462320/sample1.jpg
>>>>>>>>>>>>>>>>> The fonction SetLayout Map modify the mapdefinition in my
>>>>>>>>>>>>>>>>> layout.
>>>>>>>>>>>>>>>>> See
>>>>>>>>>>>>>>>>> image
>>>>>>>>>>>>>>>>> here :
>>>>>>>>>>>>>>>>> http://n2.nabble.com/file/n2462320/sample2.jpg
>>>>>>>>>>>>>>>>> The problem : the layout is not modify and i have this
>>>>>>>>>>>>>>>>> message
>>>>>>>>>>>>>>>>> An
>>>>>>>>>>>>>>>>> Have you an idea ?
>>>>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>>>>>>> mapguide-users at lists.osgeo.org
>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090320/cdca012e/attachment.html
