[mapguide-users] Custom fusion widget support in MapGuide Studio
Jackie Ng jumpinjackie at gmail.com
Thu Mar 19 19:34:28 EDT 2009
I tried to make a copy of the search widget to make some modifications, but
the the following parameters are reverted to simple text fields.
- Layer Name: (Was a read-only text field with a button to spawn a layer
picker)
- Search Filter: (Was a read-only text field with a button to spawn the
Expression Editor)
- Result Columns: (Was a mini-grid to add/edit/remove name/value pairs)
Does Studio present specific user interfaces for specific widgets?
- Jackie
Chris Claydon wrote:
> There are several supported parameter types in the widget info, though I
> don't think they are documented anywhere right now.
> Try finding a pre-existing widget that has similar parameters, and look at
> its widget info file.
> Note that the supported types are not very complex, but you should be able
> to get checkboxes for Booleans, combo boxes for options with a restricted
> set of values, fields with browse buttons for selecting resource IDs,
> color pickers for colors etc.
> Chris.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Wednesday, February 11, 2009 7:35 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Custom fusion widget support in MapGuide Studio
> Hi All,
> When I create and register a custom fusion widget, I can see it in the
> list
> of available widgets. But when I edit the widget parameters in MapGuide
> Studio, all the parameters are plain text fields. Is this the normal
> behaviour?
> - Jackie
> http://n2.nabble.com/Custom-fusion-widget-support-in-MapGuide-Studio-tp2312828p2312828.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Custom-fusion-widget-support-in-MapGuide-Studio-tp2312828p2506099.html
