[mapguide-users] Legend and runtime Layer filter
Matteo matteo.conte1979 at libero.it
Sat Mar 21 15:46:18 EDT 2009
Hi Kenneth,
  I read with more attention the bug description and there are some
differences with my problem. In the bug description I read the the problem
occurs when the check "Display in legend" is set to false. Now I have try to
set layer visibily and "Display in legend" to true but I have the same
result.
I think that the problem is the runtime filter.
If you want to see my code I have a ASP.NET test project to reproduce then
problem.
Regards,
Matteo
Kenneth Skovhede, GEOGRAF A/S wrote:
> Yes, but since the bug is not yet fixed, it is also present in 2.0.2.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Matteo skrev:
>> Hi,
>>   thanks for the answer. The bug is about 1.2 version of mapguide but i
>> work
>> with 2.0.2 version.
>> Regards, Matteo
>>> That is unfortunately a long standing bug:
>>> http://trac.osgeo.org/mapguide/ticket/167
>>> You must manually itterate all layers in the layerdefinition,
>>> and add the information to the runtime map after startup.
>>> Matteo skrev:
>>>> Hi All,
>>>>   I have some Layer Groups that are hidden when Map is load. When I
>>>> active
>>>> the layer group I apply a filter runtime (change the layerdefinition of
>>>> the
>>>> layers) to the Layers of group, set the legend visibility of group at
>>>> true,
>>>> and refresh the map. I see the objects in the map but I don't see the
>>>> group
>>>> in the legend.
>>>> If I don't set a filter to the layers I see the group in the legend.
>>>> Why?
>>>> Can you help me?
>>>> Thanks
>>>> Matteo
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Legend-and-runtime-Layer-filter-tp2249502p2514723.html
