[mapguide-users] Urgent MGOS stability problem
marius.360 marius at osssa.co.za
Wed Mar 25 05:27:02 EDT 2009
Have you posted this file (for memory leak problem) now? Is it under the same download url that you posted earlier? I still seem to only get MgStylization.dll
Marius
I forgot to post another file ( which is solving memory leak).
Anyhow, there is still bug which will cause MG to stop when working with
rasters. It is hard to repeat it and find a cause. Bug pop up when you
tried to browse map from multiple clients. MG halts and in log file is
unclassified exception while stylizing (one unclassified error is fixed
with dll I posted).
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of marius.360
Sent: Tuesday, March 24, 2009 1:33 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Urgent MGOS stability problem
Harris,
I have implemented these files, I will monitor and see if it helps.
Regarding the two bugs, #726 and Ticket #480, do you think I am affected
by it, will all mapguide os sites be affected by it? I am not a
developer, so I am a bit clueless about that. Do you have a site that
has the potential of more than 55 connections, and if so have you
experienced this problem? Rasters are still a problem for me as well,
apart from these two bugs. Any comments will be helpfull.
Marius
We have simillar problems on customer site. We found that we have
problems with rasters.
Same problems are with MG ENT and with MGOS and also not working
correclty using either Autodesk or OsGeo raster provider.
Up to now, I have found 2 bugs in MG server code. I fixed those bugs and
It works better for us now but still not completly ok (latest version
yet to be tested at customer site).
If you want to try it, here is file to replace:
http://www.sl-king.com/download/MgStylization.rar
Unrar and replace over your existing file.
Haris
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context:
http://n2.nabble.com/Urgent-MGOS-stability-problem-tp2508362p2526257.htm
l
View this message in context: http://n2.nabble.com/Urgent-MGOS-stability-problem-tp2508362p2531445.html
