[mapguide-users] Urgent MGOS stability problem
marius.360 marius at osssa.co.za
Tue Mar 24 08:32:33 EDT 2009
Harris,
I have implemented these files, I will monitor and see if it helps. Regarding the two bugs, #726 and Ticket #480, do you think I am affected by it, will all mapguide os sites be affected by it? I am not a developer, so I am a bit clueless about that. Do you have a site that has the potential of more than 55 connections, and if so have you experienced this problem? Rasters are still a problem for me as well, apart from these two bugs. Any comments will be helpfull.
Marius
We have simillar problems on customer site. We found that we have
problems with rasters.
Same problems are with MG ENT and with MGOS and also not working
correclty using either Autodesk or OsGeo raster provider.
Up to now, I have found 2 bugs in MG server code. I fixed those bugs and
It works better for us now but still not completly ok (latest version
yet to be tested at customer site).
If you want to try it, here is file to replace:
http://www.sl-king.com/download/MgStylization.rar
Unrar and replace over your existing file.
Haris
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Urgent-MGOS-stability-problem-tp2508362p2526257.html
